Stick Welder Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 02:53 PM   #1
Stick welder receptacle
I bought a Lincoln ac-225-S arc welder from someone and he gave me a 30' 10/3 extension cord with it. The specs on the welder panel call for 50 amps max input on 20% duty cycle. Is the 10 ga. wire really sufficient for this welder? I will also be installing a receptacle for the welder, will a 30 amp breaker on 10/3 do the job or do I need to move up to 8 ga. on 40amp or 6 ga. on 50 amp? If I go up to a 40 or 50 amp breaker can I even use that extension cord? I doubt I would ever weld anything thicker than 3/16" to 1/4" max.
MisterSteve is offline   Reply With Quote
Old 04-28-2012, 04:38 PM   #2
I=E/R
a7ecorsair's Avatar
I have a 225 amp Lincoln welder and the factory cord is #12 wire with a molded 50 amp plug - NEMA 6-50.
a7ecorsair is offline   Reply With Quote
Old 04-28-2012, 05:03 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Are you absolutely certain?
Old 04-28-2012, 05:04 PM   #4
You are installing a 50A receptacle in a residence. Regardless of the odd codes for welders just use #6 on a 50A breaker.
It's the safest thing in the long run.
Old 04-28-2012, 05:17 PM   #5
I=E/R
a7ecorsair's Avatar
This was my first reaction too.
The Following 2 Users Say Thank You to a7ecorsair For This Useful Post:
frenchelectrican (04-29-2012), Speedy Petey (04-28-2012)
30 amp gen to 50 amp welder bmobile Electrical 11 01-23-2012 09:24 PM
continuous load anesthes Electrical 50 01-14-2012 01:35 PM
Powering a 240V stick welder with a portable generator. sdoss Electrical 2 05-19-2011 01:04 PM
Switched Receptacle Question MrBill_DIY Electrical 3 11-21-2010 11:07 PM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 02:04 AM
