Old 10-29-2012, 07:31 PM   #1
Steel stud electrical box flex
It's been a few years since I've done electrical with steel stud's in residential. I'm about to do a job and I remember way back people adding a backing support of drywall or scrap 2x4's so the boxes don't flex.
If the wall is to be drywalled, I don't believe the box needs to be supported behind if the receptacles and switches are face mounted onto the drywall. Correct or no?
n0c7 is offline   Reply With Quote
Old 10-29-2012, 09:15 PM   #2
Semi-Pro Electro-Geek
As long as there are drywall screws into the metal stud near the box, it shouldn't flex noticeably.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-29-2012, 09:17 PM   #3
Licensed Electrician
k_buz's Avatar
These are what is commonly used.
http://meproducts.net/products?subcategory=G26
Location...Location...Location
Old 10-30-2012, 12:00 PM   #4
J. V.'s Avatar
It is a good idea and a requirement that the box be mounted securely/properly.
And I have seen many installations where no extra support was provided and the boxes were solid. The conduit was assisting in supporting the boxes. Some inspectors will flag this.
I would use some of the metal framing laying around to make a bracket to mount the boxes to. Or buy some of the brackets shown above.
If the metal is gone, use a piece of 2x4. Drywall is not suggested for anything but its intended purpose.
Old 10-30-2012, 10:45 PM   #5
What's the big deal especially if the plugs/switches are face mounted to the drywall? It's never going to flex. I can see if the hole is cut too large and you have to bend the ears and install the plug/switch directly to the box but if not it seems like a wasted effort.
How to avoid underground flex PVC and electrical lines BrandonC_1972 Building & Construction 0 05-04-2012 11:31 PM
Grounding steel drain pipe Jaxx Electrical 15 04-20-2012 06:44 AM
Steel Stud Device Box Installation tjames Electrical 3 09-15-2011 12:30 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
