Steel Stud Device Box Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 12:01 AM   #1
I've worked lots with wood studs before but the builder of my current home used steel studs in the basement so I'm not sure how to mount the "steel stud" boxes I have.
I bought something like this:
http://www.homedepot.ca/product/devi...el-stud/977536
Now my really silly question, which I can't seem to find an answer for, is do I mount the box on the flat side of the stud and wrap the built in strap on the box around the flanges (the C part of the stud) or do I mount it on the C part of the stud and wrap the strap around to the flat part of the stud?
tjames is offline   Reply With Quote
Old 09-15-2011, 05:08 AM   #2
Code05's Avatar
Rewards Points: 1,104
Put the box on the flat part of the stud and screw the bracket to the face of the stud. Additional screws can go into the flat part through the side bracket.
Code05 is offline   Reply With Quote
Old 09-15-2011, 11:15 AM   #3
Also, am I allowed to use cable ties to attach the romex to the steel studs?
Do I have to use a screwed in cable tie or can I just put the cable in the middle of the stud and strap it down?
Old 09-15-2011, 11:30 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Cable ties are allowed here.
Make sure you use the bushings for the studs to run the wire through.
Metal Studs for Ceiling? fivecitydjs Remodeling 14 08-06-2009 01:32 PM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
Steel Studs Moisture problem bobdd Remodeling 21 06-29-2009 09:06 AM
Improper Installation of Steel Composite Tub House_Amuck Plumbing 1 03-19-2007 03:50 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
