Steel Stud Box Mounting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 10:57 AM   #1
Question
I've recently finished my basement and was wondering if it is possible to mount regular device boxes for wood to steel studs. Ive got about 20 of these laying around and was wondering if there was a way i could use them?
mj876 is offline   Reply With Quote
Old 02-27-2010, 11:12 AM   #2
Licensed electrician
Rewards Points: 1,622
Are you asking about using plastic nail-on with metal studs?
Old 02-27-2010, 11:15 AM   #3
No their regular metal boxes without the brackets for metal studs. I was just trying to find out what kind of creative ideas people had to make these work with metal studs.
Old 02-27-2010, 11:39 AM   #4
Electrician
Rewards Points: 794
Yeah you can but it may get a little more tricky. If your going on the closed side of the stud you just have to screw them on. If your on the open side you will have to put aother piece of stud to give you a solid surface to screw on.
In metal studs you need support on both sides of the box so you will have come up with someway to attach another stud to the other side of the box. SO when the drywal goes up the side away from the stud will not move back and forth.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
mj876 (03-05-2010)
Old 02-27-2010, 11:51 AM   #5
I had a few 2x4's laying around and cut out a few blocks and put them on the inside of the stud and screwed the device box through the closed side of the metal stud and into the block of wood on the inside of the metal stud. Should that work? It looks good and sturdy.
Old 02-27-2010, 12:18 PM   #6
Rewards Points: 160
It's a perfect idea! Good and sturdy and easier/safer than cutting metal studs.
The Following User Says Thank You to J. V. For This Useful Post:
mj876 (03-05-2010)
Old 02-27-2010, 02:16 PM   #7
Alright guys thanks for the input.
Tags
box , device , metal , steel , stud
A Garage Steel Stud partition wall PaliBob Building & Construction 8 02-16-2009 03:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
steel stud questions drewhart Carpentry 4 08-20-2008 08:39 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 12:28 AM
Stud mounting on Aluminum studs DK75 General DIY Discussions 2 02-17-2006 08:24 AM
