Steel Fish Tape Broke - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 02:42 PM   #1
Rewards Points: 1,634
Steel fish tape broke
I have a broken Klein 1/8" steel fish tape. 125' long but broken I think there is 80' or so left in the reel.
How do I "bend" the end to make the hooking loop thingie?
Or is there a retrofit "head" I can clamp on to the end to make a new head?
Or should I drill a small 1/16" hole and thread a couple of strands of wire through to make a soft loop?
Is it even worth repairing? I hardly ever need one may be a couple of times a year the most.
Are the new fiberglass ones better for fish conductors through conduits?
miamicuse is offline   Reply With Quote
Old 07-06-2013, 02:47 PM   #2
Electrician
Rewards Points: 794
A pair of linesman and channel locks should get you a nice new head.
darren is offline   Reply With Quote
Old 07-06-2013, 05:11 PM   #3
deverson's Avatar
Rewards Points: 77
Put it in a vise. Heat the last 1 1/2 " red hot. Bend the last 1/2" tight and then bent a hook about again and let cool.
deverson is offline   Reply With Quote
Old 07-06-2013, 07:21 PM   #4
Master Electrician
Or just use pliers as previously stated.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-06-2013, 07:22 PM   #5
Master Electrician
Fibertapes are generally used for applications where you may end up in a live panel or live electrical room. They aren't all that rugged.
Old 07-06-2013, 07:49 PM   #6
Rewards Points: 150
you will end up with an even shorter tape. Bending a small hook will usually snap the end it is better to heat it and bend a small hook.
RIP EJT
usair is offline   Reply With Quote
The Following User Says Thank You to usair For This Useful Post:
MTN REMODEL LLC (07-06-2013)
Old 07-06-2013, 08:11 PM   #7
deverson's Avatar
Rewards Points: 77
From the ideal site.
Pretty tough to fashion with pliers
http://i1332.photobucket.com/albums/...psa1568e5a.jpg
Old 07-07-2013, 07:41 AM   #8
Electrician
Rewards Points: 794
Are you guys electricians? I have bent my own hook numerous times. Bend it over with your linesman, flatten it out with channel locks and tape it up.
It does not have to look like the hook in the picture.
The Following 2 Users Say Thank You to darren For This Useful Post:
jbfan (07-08-2013), wirenut1110 (07-07-2013)
Old 07-07-2013, 07:47 AM   #9
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I definitely don't bend it like the picture. Even with tape, it gets hung up on the way back in a panel, box, etc.
I bend it back like a teardrop so to speak.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
darren (07-07-2013)
Old 07-07-2013, 07:48 AM   #10
Rewards Points: 150
Grandpa use to say their are a hundred ways to do it but only one right way.
RIP EJT
Old 07-07-2013, 07:49 AM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
No it's not. You DO NOT need that silly double-loop thingy. Just bend it over once.
Old 07-07-2013, 07:57 AM   #12
Rewards Points: 150
You don't need a parachute when you jump out of a plane you will be fine on the trip down.
The bull nose serves a purpose other than something to hook the wires to it also allows you to push the tape into the conduit and the double bull nose allows you to pull the tape out without it hanging up.
RIP EJT
Old 07-07-2013, 08:14 AM   #13
Licensed Pro
Just add one of these to the end. http://www.idealindustries.com/prodD...?prodId=31-148
Old 07-07-2013, 08:19 AM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you can't pull a fishtape out of a conduit without the second loop on the end, you need to stop running conduit.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
darren (07-07-2013), Speedy Petey (07-07-2013), stickboy1375 (07-07-2013)
Old 07-07-2013, 11:49 AM   #15
deverson's Avatar
Rewards Points: 77
I don't like the idea of that sharp edge with some 33 on it. A few too many times the tape has slid off the end and after a loud boom some wire has to be replaced.
What causes bubbles in paper tape? ponch37300 Drywall & Plaster 34 05-25-2013 10:50 AM
Electrical Friction Tape maddog1 Electrical 10 04-16-2013 12:03 PM
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 03:52 AM
