Steel Building Questions? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 07:39 PM   #16
Electrician
Originally Posted by Arcmaster View Post
The reason I'm running Alum. is the cost. is about half.
If you are running al mc inside, make sure all of your devices are listed for use with al.
dawizman is offline   Reply With Quote
Old 10-26-2012, 07:43 PM   #17
The only wire that i planed on running Alum. was the service wire due to the cost, but if it will be more headache then I will get #2 copper.
Arcmaster is offline   Reply With Quote
Old 10-26-2012, 07:51 PM   #18
Electrician
Also, make sure you are using anti-shorts at each mc connector. Many diyers forget to do this.
The Following User Says Thank You to dawizman For This Useful Post:
Arcmaster (10-26-2012)
Old 10-26-2012, 07:54 PM   #19
Electrician
Al is pretty common on larger conductors. As long as it is installed with compatible devices and you use noalox, or similar, you will never have any trouble and save yourself a pile of cash.
Old 10-26-2012, 08:03 PM   #20
Sparky
Rewards Points: 510
I'm nearly certain he means Aluminum Armor MC Cable. Copper Conductors.
Techy is offline   Reply With Quote
The Following 2 Users Say Thank You to Techy For This Useful Post:
Missouri Bound (10-26-2012), mpoulton (10-26-2012)
Old 10-26-2012, 08:12 PM   #21
Yes, I will be using Aluminum Armor MC Cable inside the building. But from my local elec. supply company I can get 2/0,2/0,2/0 service cable that has Alum. conductor wire.
Old 10-26-2012, 08:18 PM   #22
Master Electrician
Rewards Points: 3,964
Anti-shorts are not required with MC cable under the NEC.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Jim Port (10-26-2012)
Old 10-26-2012, 08:43 PM   #23
Electrician
I was not aware of that. They usually come with a roll of mc, so I have always used them. I will have to take a look in the cec to see if it says the same.
Old 10-26-2012, 08:55 PM   #24
Master Electrician
I use them too.
Old 10-26-2012, 09:03 PM   #25
Missouri Bound's Avatar
That answers my question.....thank you. And yes, my question was regarding the "12-2" aluminum you mentioned.
Do you want it your way or the right way?
Old 10-26-2012, 09:06 PM   #26
Here is what i want to add. Let me know what you think?
U values for steel building, heat loss viper HVAC 7 07-13-2012 03:22 PM
Steel building price trends. When to buy?? viper Building & Construction 1 12-20-2010 11:15 AM
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 04:16 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 04:36 PM
Handrail building code questions - Canada Peterpantz Carpentry 7 10-26-2008 12:24 PM
