Steal A 220 Leg For Lightbulb - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2014, 01:05 AM   #1
Rewards Points: 166
Steal a 220 leg for lightbulb
I have a well where the pipes out at the wellhead are freezing up in this cold snap. I'd like to put a lightbulb in the housing to keep things warm enough to not freeze. The only power out there is the 220 for the well pump and it's about 100 yards from the house. I don't really want to dig a new 100 yard ditch in frozen ground to bury some 14/2 just for a lightbulb.
Can I tap one leg of the 220 supply for the pump to power the lightbulb?
(I understand the pump needs a dedicated circuit by code)
dftc is offline   Reply With Quote
Old 02-06-2014, 02:01 AM   #2
Rewards Points: 166
I think I have found the answer to my own question.
Technically, yes. But only if an insulated neutral is available (which isn't always the case).
Old 02-06-2014, 06:15 AM   #3
DIY staff
Rewards Points: 7,174
Go to an electrical supply house and get a 220 socket and bulb---or get a small 220 baseboard heater---just a thought---
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
gregzoll (02-06-2014), Kyle_in_rure (02-06-2014), mpoulton (02-08-2014)
Old 02-06-2014, 06:16 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
It's actually almost never the case.
In all my years I have never seen a neutral run to a well head. Even in a pump house where it would be a benefit.
I have seen separate circuits run though.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (02-06-2014)
Old 02-06-2014, 07:23 AM   #5
Electrical Enthusiast
Rewards Points: 504
Do this.
It is very unlikely you have an insulated neutral ran to your well.
Kyle_in_rure is offline   Reply With Quote
Old 02-06-2014, 07:52 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
240 to 120 step down transformer. You can find 100 watt for less than $20. 300 watt for less than $30.
Coastal South Carolina
Old 02-06-2014, 11:11 AM   #7
Rewards Points: 768
you could use something like that
http://www.automationdirect.com/adc/...ters/060000-00
carmusic is offline   Reply With Quote
Old 02-06-2014, 02:54 PM   #8
Rewards Points: 166
Thanks for the good answers.
Just to complete my understanding a little more, could I technically just wire two 120v lights in series instead of the normal parallel setup.
I get why this is maybe a bad idea for future-proofing against people who don't know what I did, but my pipes are freezing now and my access to other options is limited mostly to mail order.
Old 02-06-2014, 05:04 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Run an extension cord if you are in a bind.... Never mind, just saw the footage.
Old 02-06-2014, 06:09 PM   #10
If it were me, depending on the size (amperage) of the pump I'd put in a small pump house heater made specifically for this application. At 500 watts it's only 2A @ 240v, so putting it on the pump circuit is entirely feasible.
http://www.amazon.com/Dayton-2YV13-E.../dp/B001H4O1J4
Old 02-06-2014, 06:36 PM   #11
E2 Electrician
Exactly, those are what I install, why do people get the notion a light bulb will stop anything from freezing?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (02-06-2014)
Old 02-06-2014, 07:59 PM   #12
Rewards Points: 266
Maybe I don't understand the situation but I don't think you'd want to tap the line going into the wellhead- it's downstream from the pressure switch and pump controller, which where I live, are both normally located in the basement by the pressure tank.
junkcollector is offline   Reply With Quote
Old 02-06-2014, 08:07 PM   #13
E2 Electrician
Pump house, not well head.
Old 02-06-2014, 08:11 PM   #14
Rewards Points: 266
Old 02-06-2014, 08:17 PM   #15
Rewards Points: 504
In my area a direct line is run to the well house and from there to the pressure switch, so there Is constant power available at the well.
Varies by location I'm sure.
W&H Molder A Steal Of A Deal BigJim Tools 2 12-09-2013 07:24 PM
Can I steal ground? SouthboundJones Electrical 14 06-03-2013 06:54 AM
Would a Bubba Steal a Tool? user1007 Tools 16 12-27-2011 08:03 PM
Dummies attempt to steal copper rgsgww Electrical 4 04-29-2009 06:56 PM
How to Reinforce Steal I-Beam sranders0n Building & Construction 12 07-25-2008 10:49 PM
