Static In Me, Outlet Noises - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 12:57 PM   #1
Static in Me, Outlet Noises
I am renting a house and the strangest things have been happening since shortly after moving in. I am full of static but not in a way that I shock myself as one would normally think - it just raises my hair to a point of unmanageability and is turning it to straw.
I also am hearing little "clicks" from the wall outlets, moreso now than ever. It seems to affect me with soundwaves (long story) and I am so full of anxiety all the time now that I cannot live with my Mother any longer. I have recently acquired extra-sensitive hearing (don't know how or why) and because she won't wear her teeth, she whistles when speaking and puts me into huge startle mode. She is 87 and it's a trying situation anyway, but my symtoms have made it impossible for us to get along now.
As I sit at my computer, I hear a noise in the wall, then hear a hissing/buzzing sound from the computer and am wondering if my proximity to it is only adding to everything else going on here. The house was remodeled awhile back but someone told me it appears as if they did a good job where electrical is concerned. Could it be I am attracting curents for some reason? I don't even know if this is humanly possible but I am in dire need of help and cannot afford an electrition to go through the entire house.
Please, any help would greatly be appreciated!
patricia1951 is offline   Reply With Quote
Old 04-17-2012, 01:18 PM   #2
Rewards Points: 150
I think you should see a specialist. You should look up Dr. Banner. Dr. Bruce Banner is a specialist in these kinds of things.
knotquiteawake is offline   Reply With Quote
Old 04-17-2012, 01:51 PM   #3
Too Short? Cut it Again!
Old 04-17-2012, 01:57 PM   #4
Rewards Points: 150
Good point Sdsester. I would also like to recommend Dr. Peter Venkman or Dr. Raymond Stantz as well, they are very well versed in these situations as well.
Also see if you can talk to your local Scientoligist (thats a guy who studies scientific stuff like this) and borrow his E-Meter which is a device that is "used to measure the state of electrical characteristics of the 'static field' surrounding the body" http://en.wikipedia.org/wiki/E-meter
Old 04-17-2012, 01:57 PM   #5
Old 04-17-2012, 02:04 PM   #6
Seriously, I do not mean to make fun but you made it too tempting.
It sounds like you should seek out some mental health counseling and that you have a lot going on to stress you out. I make the suggestion with nothing but kindness and concern in mind. Seeking such help is certainly nothing you should feel ashamed about.
Old 04-17-2012, 02:10 PM   #7
Not a good recommendation. He is still a little too green.
Old 04-17-2012, 02:16 PM   #8
Rewards Points: 150
You gotta admire his passion and intensity though
Old 04-17-2012, 02:49 PM   #9
I've heard I wouldn't like him when he is angry though!
Old 04-17-2012, 05:41 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Since you are renting, this belongs to the landlord as well as a doctor!
Maybe Dr. Who!
Old 04-17-2012, 06:39 PM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
High EMF's have been known to have this affect on people. However, you rent this property, and any electrician you bring in would not be able to perform work without the property owner's consent. You either need to hire an electrician who has an EMF meter just to check if that COULD be the problem, or contact the landlord.
The Following User Says Thank You to k_buz For This Useful Post:
Jeeps (04-17-2012)
Old 04-17-2012, 07:19 PM   #12
Rewards Points: 121
It sounds like you have low humidity levels. Maybe you could get a relative humidity meter and check that. Low humidity causes a lot of static and dry hair issues.
readar is offline   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
