06-03-2012, 09:45 PM
#1
Starting down the big hill
06-03-2012, 10:16 PM
#2
Average Joe/ex-Navy IC3
Looks about as fun as friends of ours had in Blue Grass IA. About the same circumstances.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
06-03-2012, 10:18 PM
#3
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
06-03-2012, 10:30 PM
#4
Electrical Contractor
What size service wire and conduit are you running. Is the second conduit for communications cable?
A hill like that a heavy ball with string could be used to get your pull rope in there. LOL
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
06-04-2012, 12:19 AM
#5
JOATMON
There is a reason the wire pull lube comes in 5 gallon buckets....
You won't be using a pull string....you will be using a rope....
I would pull from top to bottom....get what little help you can from gravity....
And you can rent a motorized pull wheel....makes the job a lot easier....
Is this going to be 220 single phase? At that distance, it would almost justify a higher voltage (4160) with a step down xfomer at you the point of use.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
06-04-2012, 02:36 AM
#6
Semi-Pro Electro-Geek
That seems like too long of a run for 240V to be cost effective.
06-04-2012, 05:33 AM
#7
Looks like fun,what size it your duct?
In this long of a pull bigger is easier.
Yea and rent a tugger.
U.S.M.C. "80-84" E.O.D. 1369
06-04-2012, 06:57 AM
#8
It's for 7.2kv primary. Running late for work, will post more info later.
The Following User Says Thank You to zappa For This Useful Post:
06-04-2012, 07:20 AM
#9
use a puller
Electricity will kill you if you give it a chance
06-04-2012, 08:05 AM
#10
Originally Posted by bubbler
The vacuum will pull the string right through and then you can use it to pull your wires.
Are you kidding me. A string to pull 900' of wire?
06-04-2012, 04:29 PM
#11
E2 Electrician
Originally Posted by hammerlane
You pull the string first, then a rope, a rope is to heavy to be sucked through by a vacuum.
The Following User Says Thank You to stickboy1375 For This Useful Post:
06-04-2012, 04:35 PM
#12
E2 Electrician
Cotton balls? They make these...
06-04-2012, 04:40 PM
#13
Lic Electrical Inspector
[quote=zappa;935598]600' long hill with a steep grade the entire distance. 900' between the pull points. I wasn't looking foward to this part.
I did 400' of (3)4/0 CU and (1) #4 CU recently without any pull boxes. Big mistake. I would have put a few pull points atleast. Any 90's in the run? Good luck you'll need it.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
06-04-2012, 05:39 PM
#14
I wouldn't bury your ducts completely until you are done pulling your wire.
Should we tell him about static build up or let him find out on his own?
06-04-2012, 05:41 PM
#15
E2 Electrician
Power company around here would never let that distance fly, they would require a few pull boxes.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
