-   -   Starting down the big hill (http://www.diychatroom.com/f18/starting-down-big-hill-145872/)
zappa 06-03-2012 09:45 PM
2 Attachment(s)
600' long hill with a steep grade the entire distance. 900' between the pull points. I wasn't looking foward to this part. :(
Attachment 51908
Attachment 51909
gregzoll 06-03-2012 10:16 PM
Looks about as fun as friends of ours had in Blue Grass IA. About the same circumstances.
bubbler 06-03-2012 10:18 PM
You'll need a shop vac, some cotton balls, and string... Tie the cotton balls to the string. Put them in one end of the conduit. At the other end of the conduit shove your shop vac hose. The vacuum will pull the string right through and then you can use it to pull your wires.
:jester::jester::jester::jester:
rrolleston 06-03-2012 10:30 PM
What size service wire and conduit are you running. Is the second conduit for communications cable?
A hill like that a heavy ball with string could be used to get your pull rope in there. LOL
ddawg16 06-04-2012 12:19 AM
There is a reason the wire pull lube comes in 5 gallon buckets....
You won't be using a pull string....you will be using a rope....
I would pull from top to bottom....get what little help you can from gravity....
And you can rent a motorized pull wheel....makes the job a lot easier....
Is this going to be 220 single phase? At that distance, it would almost justify a higher voltage (4160) with a step down xfomer at you the point of use.
mpoulton 06-04-2012 02:36 AM
That seems like too long of a run for 240V to be cost effective.
Ravenworks 06-04-2012 05:33 AM
Looks like fun,what size it your duct?
In this long of a pull bigger is easier.
Yea and rent a tugger.
zappa 06-04-2012 06:57 AM
It's for 7.2kv primary. Running late for work, will post more info later.
Julius793 06-04-2012 07:20 AM
use a puller
hammerlane 06-04-2012 08:05 AM
Are you kidding me. A string to pull 900' of wire?:laughing::laughing::laughing::laughing:
stickboy1375 06-04-2012 04:29 PM
12 Attachment(s)
You pull the string first, then a rope, a rope is to heavy to be sucked through by a vacuum.
stickboy1375 06-04-2012 04:35 PM
12 Attachment(s)
Cotton balls? They make these...
http://www.greenlee.com/images/PISTO...81288cc23a8223
electures 06-04-2012 04:40 PM
[quote=zappa;935598]600' long hill with a steep grade the entire distance. 900' between the pull points. I wasn't looking foward to this part. :(
I did 400' of (3)4/0 CU and (1) #4 CU recently without any pull boxes. Big mistake. I would have put a few pull points atleast. Any 90's in the run? Good luck you'll need it.
Ravenworks 06-04-2012 05:39 PM
I wouldn't bury your ducts completely until you are done pulling your wire.
Should we tell him about static build up or let him find out on his own?
stickboy1375 06-04-2012 05:41 PM
12 Attachment(s)
Power company around here would never let that distance fly, they would require a few pull boxes.
