Stapleing Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 02:19 PM   #1
Rewards Points: 640
stapleing question
I know wires need to be "stapled" in place within 8-12 inches from a junction box and every 36" to 48" as it runs down a joist or stud.
Now, when a wire goes through a boared holes in a joists that are 16" O.C., say the joist direction now changes so you can not go through boared holes and you have to staple the line along the joist that is parallel to it. How soon after the line leaves the boared joist does it need to be stapled to the parallel joist it then runs against?
attached a small example pic with the joists going vertically first then switching to horizonal with the wire going through it (in gray)
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 12-17-2012, 04:44 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
4 foot.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
NJMarine (12-17-2012)
Old 12-17-2012, 05:04 PM   #3
Rewards Points: 640
Originally Posted by electures View Post
4 foot.
ah, so the last joist does count as a location holding the cord like a staple does. thanks!
Old 12-17-2012, 06:27 PM   #4
electures's Avatar
Bored holes are considered secured and supported.
Old 12-17-2012, 07:14 PM   #5
Master Electrician
Rewards Points: 3,678
4 foot.
Could that be 54"?
brric is offline   Reply With Quote
Old 12-17-2012, 07:57 PM   #6
Licensed electrician
Rewards Points: 996
Originally Posted by brric View Post
Could that be 54"?
I heard something like 4'-6".
Old 12-17-2012, 09:27 PM   #7
Master Electrician
Aren't you so clever.
Old 12-18-2012, 12:53 AM   #8
TTW
TTW's Avatar
Could that be 54"?
But I don't have nice little arrow markers on my tape measure At 54"
Every 4' is where the 16" markers and the 12" markers line up!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
