Standby Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 08:32 PM   #1
Handyman
brucem609's Avatar
Rewards Points: 79
Standby generator
I am in the market for a generator for my house, not to do the whole house, but in case of a long outage. I am thinking this might be a bad winter in the northeast. I do not need it to take care of the whole house but I want it to run the fridge, freezer, router, TV, some lights.
I just have to get the wife and daughter to turn off what's not needed-right!
if I get a 5000watt generator is there a way to tie it back into the panel so it will run what I need?
I am a novice when it comes to electrical issues.
What do I have to do, but, install?
Any help is appreciated
Sent from my iPad using DIY Forum
brucem609 is offline   Reply With Quote
Old 10-22-2013, 08:58 PM   #2
Rewards Points: 1,016
I have a generator inlet connection near my breaker box - it's simply wired to a breaker added in the breaker box. A physical lockout mechanism is installed in the breaker box that only allows the added generator breaker to be ON if the main breaker is OFF. This precludes the generator from sending electricity back out over the power company wires - and is a must for safety of power company maintenance persons. And yes, you simply manage what you have turned on in the house so as to not exceed the generator capacity. To me this is the simplest and most flexible way to connect such a portable generator for occasional emergency use.
Another common way to connect a generator is via a transfer switch. The inlet connection is connected to the transfer switch, which has it's own circuit breakers and is wired in to take over (transfer) selected circuits on your breaker box.
____________
Vince
Old 10-22-2013, 11:20 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,610
We need to know more about your main panel ?
Is there room for a lock out ?
Are lock outs available for your brand of panel ?
And you will need an inlet ?
Can you post a picture of your main panel ?
dmxtothemax is offline   Reply With Quote
Standby generator on/off switch Jeremy Hillary Boob, PhD Electrical 27 12-14-2014 02:18 PM
standby generator installation cost newhomenj Electrical 54 12-26-2012 07:16 PM
Natural Gas Standby Generator - Multiple Questions wildbilll Plumbing 3 01-17-2012 05:46 PM
Standby Generator & Transfer Switch JRoot Electrical 9 06-12-2011 09:14 AM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 05:35 PM
