Standard Dept To Set Back Boxes For Plaster Walls? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 10:14 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Standard dept to set back boxes for plaster walls?
I find it necessary, in order to properly plaster around my boxes to recess them slightly. 1/8" to 1/4" seems about right. Is this your experience as well that you need to make them slightly recessed to be able to plaster properly around them?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-02-2009, 10:59 PM   #2
You are at the max allowed, flush is best.
unclduey is offline   Reply With Quote
Old 03-02-2009, 11:07 PM   #3
Rewards Points: 2,350
Yes, seems like the surface tension of the plaster would tend to cause a lip if the box is flush. But a little sanding would probably take care of it. But I have found a little bit of recess to be better than completely flush too. 1/8" would be good, but no more than 1/4".
Old 03-02-2009, 11:17 PM   #4
liscenced electrician
Rewards Points: 538
i prefer them to be back just a hair on my own projects so that i can mud over the box a little. On jobs at work i try for flush, since the sheetrockers don't ever mud over them, they just cut around them
jimmy21 is offline   Reply With Quote
Old 03-02-2009, 11:53 PM   #5
DIY'er
jamiedolan's Avatar
Yep, I just plastered in that box in the foyer, and it stuck out too far, and I could not get the plaster floated in correctly. Most people would not really notice it, (i like to make things pretty) but I want to make sure to avoid that on my other boxes in the kitchen. I'll make sure to stick around that 1/8" to 1/4" range.
I am using a traditional plaster system, so it is not like sanding drywall mud or light weight joint compound, it's more like trying to sand your sidewalk . If I have too much plaster on, I'll seriously have to get out a disk grinder, once it is setup, cut it back and re-top coat if I overfill / bulge out around the boxes.
Plastering is kind of a lost art, but I think it is pretty cool. Looks so much nicer than rock, way tougher, water resistant, sound deadening, etc.
Jamie
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
