Standard Bulb In Recessed Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 12:44 AM   #1
Rewards Points: 518
I have new halo brand 4" recessed cans H99ICAT with 993P baffles. These fixtures with this baffle are supposed to use 50w PAR20 bulbs.
If I was to use a standard 60w incandescent bulb would there be heat issue?
I plan to use LED but they haven't arrived yet.
n0c7 is offline   Reply With Quote
Old 10-05-2013, 01:08 AM   #2
Rewards Points: 518
I ran a test knowing these had a thermal shutoff. Less than 20 minutes in a cold wind and they shut off with a 60w incandescent. Surprising since halogens are so much hotter.
Old 10-05-2013, 01:19 AM   #3
Oso954's Avatar
Rewards Points: 772
The spec actually reads a 50W PAR 20 with a H1999 socket extender.
An A19 bulb (your regular 60W bulb) is not approved with the 993 trim.
The only trim listed on their spec sheet for an A19 with that can, is the ERT413. It is limited to 40W.
Oso954 is offline   Reply With Quote
Old 10-05-2013, 01:28 AM   #4
Rewards Points: 518
Yup socket extender as well. These fixtures have been the biggest rip off.
Old 10-05-2013, 08:12 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Rip off? Please explain. It sounds like you didn't do your homework before choosing the can/trim and now it's Halo's fault.
Old 10-05-2013, 08:43 AM   #6
The rated PAR20 bulbs direct the heat downward. If you use a regular bulb..as you found...the thermal switch will not be far behind.
There is nothing wrong with the fixtures if used as directed.
RoyalAcresRod is offline   Reply With Quote
Old 10-05-2013, 12:32 PM   #7
Rewards Points: 518
I knew I needed a can and a trim but didnt know they sell a fixture rated for a 35w bulb which is impossible to find.
Fixture - $20
Trim - $17
Socket extender - $10
They should design the fixture to work with industry standard bulbs or include proper hardware. Poorly made cheap expensive fixtures. Rip off.
Old 10-05-2013, 12:40 PM   #8
k_buz's Avatar
The fixture isn't rated for any specific lamp. It's the trim that determines the lamp rating.
Old 10-05-2013, 01:38 PM   #9
Oso954's Avatar
Rewards Points: 772
Maybe you need to talk to your store managers up there. find out why you are having a problem.
A 35W PAR20 shouldn't be that difficult to find. I can walk into almost any hardware or home improvement store and pick one up. It is a very standard bulb.
That or you can go up to 50 watts with your socket extender. Either PAR 20 or R20.
This 45W R20 is a great bulb for that can.
http://www.homedepot.ca/product/45w-...-3-pack/968895
Old 10-05-2013, 01:48 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Fixture - $20
Trim - $17
Well you can always buy the $100 dollar cans.... your choice.
need help changing out light bulb gswarriorfan Electrical 13 04-17-2012 09:43 AM
converting 12 v light fixture to 110 GKA Electrical 1 06-30-2011 07:59 PM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
New bulb, old fixture - don't work Ultrarunner2017 General DIY Discussions 2 08-25-2010 02:41 AM
T12 bulb in a T8 fixture scottyja Electrical 6 11-02-2008 07:50 PM
