Stairway Lighting Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 09:18 PM   #1
Stairway lighting help
Hi all,
The stairway leading to my basement has a light only at the bottom, so the steps are not very well lit and a little dangerous at times. I'd like to add a fixture on the wall as indicated in the picture below. Are there any restrictions I need to be aware of such as size of the fixture, or specific height requirements, other than being high enough to avoid someone hitting their head on it? Thanks for any help or different ideas!
bucksfan is offline   Reply With Quote
Old 03-24-2013, 09:20 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
None what so ever.
Old 03-24-2013, 09:26 PM   #3
Many thanks
Old 03-24-2013, 09:31 PM   #4
Rewards Points: 13,300
I like to install a sconch light there, that way I can change the bulbs with out having too get out a ladder.
Old 03-25-2013, 08:52 AM   #5
Thanks joecaption, that's a great idea. I picked out a lantern style fixture, but if I can find a sconce that's bright enough, I'd like the slimmer profile for sure in that spot. Appreciate the help guys!
Old 03-25-2013, 08:54 AM   #6
I guess those stairs and door were a nonpermited job.
Old 03-25-2013, 09:08 AM   #7
I moved here a couple of months ago and thought it weird, but maybe the absence of a fixture was some sort of code variance I wouldn't have heard of. The house is only 6 yrs old and the inspector had not flagged it either, so I tried telling myself it wouldn't have passed construction inspections if it was done incorrectly What do you see regarding the door?
Old 03-25-2013, 09:39 AM   #8
No landing in front of the door.
Around here we can not have open risers like that.
LANDINGS
1. Landings are required at the top and bottom of all stairs, except at the top of an
interior stairs (provided a door does not swing over the stair).
2. Landings are required on both sides of an exit door.
3. Landings are required on both sides of all exterior doors, except a landing is not
required on the outside of a door if there is less than three risers.
4. Landings are to be at least 36Ē in length, measured in the direction of travel.
5. A door between the house and the garage is considered an interior door, and no
landing is required at the top of the stairs on the garage side provided the
security door does not swing over the landing (a screen door may swing over the
landing).
Definitions
Exit door: All dwellings are required to have at least one exit door which provides direct
egress from the habitable space to the outside (without going through the garage or
screen porch).
Exterior door: All other doors, which lead directly or indirectly to the outside.
Old 03-25-2013, 10:07 AM   #9
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
LANDINGS
1. Landings are required at the top and bottom of all stairs, except at the top of an interior stairs (provided a door does not swing over the stair).
Wouldn't that door fall under the exception for item 1? I don't see hinges, so that door would have to swing out, no?
hyunelan2 is offline   Reply With Quote
Old 03-25-2013, 10:13 AM   #10
It's concidered an exit door.
"Landings are required on both sides of an exit door"
Old 03-25-2013, 10:21 AM   #11
Rewards Points: 398
I had the same issue in my basement - I bought a pivoting wall light from Home Depot - similar to this one but with a lot less wide lamp shade (to save shoulder room - it uses the small bright twist line bulbs) and point it downward with the steps.
http://m.homedepot.com/p/Eglo-Dakar-...72A/203020788/
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
The Following User Says Thank You to adgjqetuo For This Useful Post:
bucksfan (03-25-2013)
Old 03-25-2013, 10:45 AM   #12
That light also needs to be on a 3 way switch.
Old 03-25-2013, 12:17 PM   #13
Hmm, I was thinking it would fall under the #1 exception as well as the door does not open toward the stairs and there is a very large landing at the top on the other side of the door. There is already a 3 way switch at the top and bottom. Again, thanks for all the info.
adgjqetuo, thanks for the home depot link!
Old 03-25-2013, 12:51 PM   #14
hyunelan2's Avatar
Rewards Points: 686
Doesn't sound like it according to the definition:
Exit door: All dwellings are required to have at least one exit door which provides direct egress from the habitable space to the outside (without going through the garage or screen porch).
Unless that door went to the outside, it seems it would be an interior door.
EDIT: not saying it is or isn't right, just saying that from the small excerpt you posted it would seem compliant.
Old 03-25-2013, 01:21 PM   #15
Rewards Points: 313
That is not an exit door; it is simply an interior door. Brand new houses are still built with basement stairs exactly that way almost everywhere. As long as the door swings away from the steps, it is compliant without a landing on the stair side.
And depending on the age of the house, the open stair risers are legal. In our area that did change some years back. All stair risers must be enclosed now.
al_smelter is offline   Reply With Quote
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 02:35 PM
stairway lighting Liz Beth Electrical 2 11-29-2011 04:06 PM
Stairway lighting rfillha Electrical 7 06-26-2009 12:22 AM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
