Stacked Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 08:30 AM   #1
Stacked Switches
I am looking for but not finding a stacked switch. I want it to have 1 single pole switch, this controls an outlet and is already in place. I want to add a ceiling light that would be on a dimmer on the same switch. Do they make a switch like that ?
barley is offline   Reply With Quote
Old 04-19-2013, 09:01 AM   #2
Rewards Points: 150
Something like this?
http://www.amazon.com/Lutron-MA-L3S2...ination+dimmer
One switch offers dimming control for one load and on/off control for a separate load
SquishyBall is offline   Reply With Quote
The Following User Says Thank You to SquishyBall For This Useful Post:
barley (04-19-2013)
Old 04-19-2013, 04:21 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Just be careful, that dimmer is only rated at 300 Watts. Most standard dimmers are 600W.
Old 04-19-2013, 05:36 PM   #4
Oso954's Avatar
Rewards Points: 1,106
Before you rush out and buy the switch, figure out what wiring you have and what additional wires will be required.
If that existing switch is on a switch loop, you do not have a neutral in the switch box.
Oso954 is offline   Reply With Quote
Old 04-20-2013, 07:58 AM   #5
Bill Kearney
Rewards Points: 1,174
I would not use that switch to control an outlet as it's not rated for much of a load. Plug the wrong thing into that outlet and you risk starting a fire.
Better to just replace the single gang box with a double and use the correct switches. Yes, it's a bit more work but a LOT less work that a HOUSE FIRE. There are various ways to retrofit a box. Otherwise just put another switch for it somewhere else.
wkearney99 is offline   Reply With Quote
Old 04-20-2013, 11:25 AM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Dude, the 300 w limit is for the dimmer half of the switch...which would supply his ceiling light fixture
The other half of the switch (non dimmable) is rated at 15 amps.... which would control the receptacle.
Old 04-22-2013, 10:07 AM   #7
I do have a neutral in switch box. However for the $46 price tag on the switch I might just be going with the more work route and putting in a 2 gang box instead of the stacked switch.
Also thinking about putting a single switch someplace else for the ceiling light. There isn't really another convenient place to put another switch with how the room is layed out. Except, on a 2 foot wide wall that acts as a cold air return. There is no ducting inside this wall, just a cold air return vent on the baseboard, and one vent up near the top of the wall. I don't see why it would matter, but I can drop a wire down the cold air return cavity from the attic and put a new switch on that wall ?
Old 04-22-2013, 10:39 AM   #8
Bill Kearney
Or you could put some ducting inside the wall to isolate it from the wiring you add. Generally you can't add line voltage wire and boxes inside an air plenum.
Old 04-22-2013, 03:48 PM   #9
Rewards Points: 150
For $46 if this does what you want it to, I'd just use it! ~Any~ amount of installing another box somewhere else is going to cost you almost as much in materials plus hours of time. Add up a dimmer, a switch, the cost of wire to the new location, then that location to the lights, plus box, clamps, staples, and hours of work including repairing drywall... Or...
$46, done.
The Maestro switches are good.
-mike
Old 04-22-2013, 05:07 PM   #10
Bill Kearney
Agreed, the Lutron gear is worth their prices. We've got a houseful of their Radio RA switches. We should be so lucky as to have the less expensive Maestro pricing...
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 12:37 PM
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 12:01 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 03:21 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 10:26 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
