Stackable Washer/dryer Voltage/breaker Question - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 07:25 PM   #31
Master Electrician
Rewards Points: 3,966
You are correct if that is the buss orientation. Two THQP 230's would work. We need a better picture.
brric is online now   Reply With Quote
Old 08-10-2011, 08:04 PM   #32
dmxtothemax's Avatar
Rewards Points: 5,610
So each pole measures 120v to neutral correct ?
How did you measure for 240v ?.
Did you measure across the two hots ?
If you did and you are getting nothing or close to it,
Then the two hots are probably coming from the same phase.
If so this will not work !
You need two different phases for 240v.
dmxtothemax is offline   Reply With Quote
Old 08-10-2011, 08:18 PM   #33
Master Electrician
I think he was reading voltage at the receptacle inside the house. This of course would read the same as at the breaker because the breaker is not seated properly on both busses.
Old 08-11-2011, 07:23 PM   #34
Rewards Points: 282
take a bigger picture please, because I'm pretty sure you managed to engage that breaker to one of the locking tabs for that feed wire and that no breaker is meant to be there (at least not the one you managed to jam in).
what a mess.
jcrack_corn is offline   Reply With Quote
The Following User Says Thank You to jcrack_corn For This Useful Post:
mpoulton (08-12-2011)
Old 08-12-2011, 12:19 AM   #35
Semi-Pro Electro-Geek
Rewards Points: 2,990
what a mess.
Yeah, I think that may be true. At first I thought it was the first bus position, but the breaker is sitting differently from the rest, and looks like it extends past the midline of the panel. I'm not sure that's a bus position at all, and I'm pretty sure that breaker is not proper for that panel.
mpoulton is offline   Reply With Quote
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
relocate washer/dryer krtw Remodeling 2 01-15-2006 02:39 AM
