Old 08-10-2011, 04:12 PM   #16
Average Joe/ex-Navy IC3
gregzoll's Avatar
Stackable washer/dryer voltage/breaker question
Originally Posted by fattysc View Post
New position and I'm still only getting 120 on each pole. Nothing when I test both poles together.
If I get a single pole 30mp 240 breaker. Would that matter?
You could try pulling the breaker, and inspecting the leg where it was sitting. Is there another 30 amp breaker that you can swap it with to verify if something is wrong? Also, if your meter has a continuity test function on it, you can do a continuity on the breaker out of the panel to check to make sure when the switch is "closed", that it allows current through. If the breaker is pretty old like the panel, there is no doubt that it may be bad and needs replaced.
The other question is, are you for sure that you are getting 240 out of the panel between both incoming legs in the panel?
gregzoll is online now   Reply With Quote
Old 08-10-2011, 04:23 PM   #17
Stackable washer/dryer voltage/breaker question-1.jpg
Sorry about the quality.
I have tested each leg/pole inside the home. If I test each one separately I get 120 on each leg/pole. If I test both together I get nothing. It is a brand new breaker.
I'm pretty sure I'm gonna have to get a pro out here to check whats up.
Thanks for the help though guys. Fast replies are excellent!
fattysc is offline   Reply With Quote
Old 08-10-2011, 04:30 PM   #18
gregzoll's Avatar
Need a full picture of the box, instead of a side on view. I would say that you have the wrong breaker. What does that other 30 amp feed, along with the 60 amp.
Old 08-10-2011, 04:32 PM   #19
Master Electrician
Is that the total extent of the breakers for your home?
brric is offline   Reply With Quote
Old 08-10-2011, 04:34 PM   #20
gregzoll's Avatar
To me, it looks like a outside feed for a trailer/mobile home.
Old 08-10-2011, 04:35 PM   #21
Master Electrician
That's what I was wondering.
Old 08-10-2011, 04:40 PM   #22
gregzoll's Avatar
And, I would say that that box appears to be only a six space sub-panel.
Old 08-10-2011, 04:41 PM   #23
Master Electrician
Bad photo but it does appear so. Possibly only a four space if that 60 is back-fed.
Old 08-10-2011, 06:13 PM   #24
So why can't he use a THQP230??
Master of Cold is offline   Reply With Quote
Old 08-10-2011, 06:20 PM   #25
Master Electrician
As of the current photo a THQP 2130 will not fit.
Old 08-10-2011, 07:21 PM   #26
if he gets another THQP2130 he could make it work(replace existing, would allow him to stagger the poles), but not with his current setup.
Techy is offline   Reply With Quote
Old 08-10-2011, 07:31 PM   #27
Master Electrician
Oh, really?
Old 08-10-2011, 07:38 PM   #28
assuming the panel accepts type thqp, if he takes out the thql2130, and leaves a half space at the top, then puts his 2 new thqp 2130's in it will work.
Old 08-10-2011, 07:52 PM   #29
Master Electrician
The top of what?
Old 08-10-2011, 08:10 PM   #30
top is my mistake, used to vertical style loadcenters,
here is a picture.
existing -
NEW
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
relocate washer/dryer krtw Remodeling 2 01-15-2006 03:39 AM
