Stackable Washer/dryer Voltage/breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 02:05 PM   #1
Stackable washer/dryer voltage/breaker question
So my old lady bought a used stackable washer/dryer. She said it worked as in heated up and I can confirm the washer works.
I'm using a thin double pole 30 amp 120/240v breaker for a stacked washer/dryer. When I test each pole inside the home each pole tests 120v. But, when I test both poles together I get nothing. That is after I tried a brand new breaker.
My question is if I get a single pole 30 amp 240 breaker, will it work?
I'm totally stumped. I know the heating element in the dryer can go out. But, like I said I'm not getting 240 when i test each pole together on the 240 line.
Thanks for any help.
fattysc is offline   Reply With Quote
Old 08-10-2011, 02:09 PM   #2
Rewards Points: 6,652
Thin as in Tandem can not be used for 240 volt applications. You need the proper breaker for the application, due to a tandem uses the same leg in the panel.
Old 08-10-2011, 02:11 PM   #3
This is the breaker I'm currently trying to use.
http://www.lowes.com/pd_71984-76863-...ductId=1099037
Can you please show me one that I need? It is a GE breaker.
Thank you so much for the fast reply.
Old 08-10-2011, 02:12 PM   #4
Master Electrician
Rewards Points: 3,870
Are you using a "thin" 2 pole breaker or a tandem breaker? A tandem breaker will not supply 240 volts. A "thin" 2 pole breaker(as in a GE THQP 230) must be properly positioned inn the panel to contact both busses to obtain 240 volts.
brric is online now   Reply With Quote
Old 08-10-2011, 02:15 PM   #5
Master Electrician
That is a 2 pole breaker. Install the breaker you have up or down one position in the panel. Assuming you have a GE panel that accepts THQP breakers. Some GE panels only accept THQPs in certain locations. Post a photo or the model # of the panel.
Old 08-10-2011, 02:16 PM   #6
I do believe that is the breaker in question I am using currently. Should both poles when tested together show 240v on the multimeter?
Trying new position for breaker. Will report back.
Last edited by fattysc; 08-10-2011 at 02:18 PM. Reason: Trying new position for breaker. Will report back.
Old 08-10-2011, 02:19 PM   #7
Master Electrician
Yes. 240 volts.
Old 08-10-2011, 02:29 PM   #8
New position and I'm still only getting 120 on each pole. Nothing when I test both poles together.
If I get a single pole 30mp 240 breaker. Would that matter?
Old 08-10-2011, 02:35 PM   #9
Master Electrician
What is the model number of your panel? You may need a THQL 2130 breaker instead.
Old 08-10-2011, 02:41 PM   #10
Originally Posted by brric View Post
What is the model number of your panel? You may need a THQL 230 breaker instead.
I couldn't tell you to be honest. Its so old that the markings are not there. I will try to take a picture of it later and upload it.
Old 08-10-2011, 02:43 PM   #11
Master Electrician
GE THQL 2130
Old 08-10-2011, 02:52 PM   #12
GE THQL 2130
When I said its old I mean its really old. Still functioning though. Here is the problem I can't use that big boy you showed. I only have room for one thin double pole.
If I get a single pole 240 and just double up on the wires. Will that work? If they make them?
I know its not code or anything but, if you guys think it will work that way and not be trouble. Then I think that is my last solution. Instead of putting in an entirely new panel.
Old 08-10-2011, 02:56 PM   #13
Master Electrician
It absolutely will NOT work. Are you even sure it is a GE panel?
Old 08-10-2011, 02:59 PM   #14
Yeah it definitely is a GE panel. Gimme 5 minutes. I'm gonna walk over to my cousins and get his camera.
Old 08-10-2011, 03:07 PM   #15
Semi-Pro Electro-Geek
Rewards Points: 2,938
No. The difference between a 120V and a 240V circuit is that a 240V circuit uses both 120V hots from the panel, which have 240V between them. A 120V circuit uses only one hot and neutral. A single pole breaker provides only one hot, so that is not helpful for you. A tandem breaker provides two circuits, but both on the same hot, so there is no voltage between them. Also not useful for you. You need a two pole breaker, so you have both hots, with 240V between them. Thin two-pole breakers are uncommon and not available for all panels. If you can use a thin two-pole breaker, you have to position it properly in the panel. They don't work in all slots.
mpoulton is offline   Reply With Quote
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
relocate washer/dryer krtw Remodeling 2 01-15-2006 02:39 AM
