Old 12-03-2012, 05:01 PM   #16
Stackable washer dryer power question
Originally Posted by muphtrician View Post
Ok that's what I was trying to find out. Gonna disconnect it and put back the original outlet. Can you explain why this is unsafe? Thanks.
Also... Why am I calling the landlord now?
It's unsafe because it's not wired properly.
Call your landlord so he/she can get a proper outlet installed.
This will need new wiring as it will require 10-3 wire and not the 12-2 that is there now.
sgip2000 is offline   Reply With Quote
Old 12-03-2012, 05:05 PM   #17
Well it had a regular outlet on it, they probably would just tell me no if I put in a repair request. They mentioned it had washer hook up when I moved here just didn't think too much into the dryer situation at the time.
Or are you saying it's wired wrong even for a standard outlet? The 2 switches are separate and not connected (if that is the difference between 2 pole and tandem), they can turn on/off separately.
Thanks.
muphtrician is offline   Reply With Quote
Old 12-03-2012, 05:32 PM   #18
Thanks.
A regular outlet is fine, but for the dryer outlet, it needs to have a 3rd wire for the heating element.
If you leave the dryer outlet there, it will not be wired correctly as it will not be grounded.
Also, if the apartment has a washer hookup, it should have a dryer hookup as well. Is it possibly a gas connection?
Old 12-03-2012, 05:44 PM   #19
Rochsolid's Avatar
Ya you need to call the landlord and get a qualified electrician in there to fix it up right. Typically you would run a 10/3 cable to your dryer receptacle, would read 120v from line to neutral (either red or black to white) and 240 v live to line (red to black) and you will need a 2 pole 30 amp breaker not a tandem like you have now.
Rochsolid is offline   Reply With Quote
The Following User Says Thank You to Rochsolid For This Useful Post:
muphtrician (12-03-2012)
Old 12-03-2012, 05:54 PM   #20
Cool thanks guys, I'm gonna call the landlord and see what I can do about this.
There is a solid copper wire, I'm assuming that is the ground. Just only 1 hot wire it seems.
Old 12-03-2012, 06:17 PM   #21
That receptacle you posted a photo of in your first post is not grounded.
The top slots are both "HOT" and the "L" slot is neutral.
A new installation would require a receptacle with four slots adding a ground.
Old 12-03-2012, 06:37 PM   #22
One that has 4 slots for connection on the back of the receptacle (same female connection on front)?
Old 12-03-2012, 07:47 PM   #23
No, you would have to buy a new NEMA 14-30 cord for your dryer as well.
Techy is offline   Reply With Quote
Old 12-03-2012, 07:51 PM   #24
Ok... I'm confused now. Why does my unit come stock with the other plug?
Old 12-03-2012, 07:58 PM   #25
Electrical Contractor
It comes with that plug because dryers used to be wired with 3 wires.
If you had a house with an old 3 wire installed, you could use the current setup.
Since this will be a new installation, current code calls for a 4 wire set up.
The cord would have to be replaced to match the receptacle.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-03-2012, 08:08 PM   #26
Actually, the house was built in the 40's and does have a 3 wire set up.
Old 12-03-2012, 08:17 PM   #27
But, when you install a new circuit, it needs to meet todays code, so it needs to be 4 wire.
Old 12-03-2012, 08:21 PM   #28
Oh, I see.
Another Dryer Question 3 to 4 wire John3rd Electrical 8 10-24-2011 06:54 PM
Moving Washer and Dryer upstairs from basement pennypoopie General Discussion 3 08-23-2009 06:29 PM
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Pressure Washer Question DIYchick Tools 8 02-05-2008 06:44 PM
Moved Washer, Dryer and Laundry Tub chaz Plumbing 4 11-03-2007 03:35 PM
