Stabing Back Of Receptacles In Cook County IL - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 11:00 PM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Yoyizit View Post
This says that the resi. backstabbers are 3x as reliable as the others. How can that be?
Yoyizit .,
Let me make it clear one out of 4 is damaged from back stabbing devices not the backwired devices that will make the diffrence there I have more issue with backstabbing than backwired or screw in termails for the amout of time and troubleshooting it it almost automatic once you know what era the house is set up and type of device it used you can pretty much dail in and go from there.
Merci,Marc
P.S. Thank god for France they do not have any backstabbing devices at all !!!
Old 09-21-2009, 03:34 PM   #17
Rewards Points: 338
I've never had to fix an outlet where the wires properly terminated under a screw. Dozens of back stabbed though.
petey_c is offline   Reply With Quote
Old 09-21-2009, 04:50 PM   #18
The reliability people handle zero failures by assuming that tomorrow you will find a failure of the first kind. It's 'cause using zero makes the math weird.
So it sounds like the backstabbers are ~50x less reliable and the ratio is 1:50.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 06:44 AM
Blown fuses while changing switches & receptacles marc_easy Electrical 9 07-05-2009 10:24 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
