Squeeze & Learn..slight Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2004, 08:46 AM   #1
Guest
Guest
Posts: n/a
squeeze & learn..slight problem
I'm currently working on an interactive information design project called squeeze and learn. The interface is a plush soft toy, with a built in screen, most probably pocket pc on its belly. A child is supposed to squeeze the toys hands to trigger a flash presentation on the pocket pc. My problem is how to make myself a sensor that can somehow trigger the pocket pc.
Here's my idea so far : To use a camera release cable to 'keypress' a keyboard connected to the pocket pc. The keyboard does not necessarily have to be built in, just hidden somewhere.
Now my question: What should I use for the squeezing part, and somehow press down the camera release that will then press the keyboard? Or does anyone have a better idea to do this whole thing?
Thanks for your help
Old 02-06-2004, 06:46 PM   #2
You could hard wire a metallic pushbutton to the pocket pc. I don't know the technical term - but like calculator buttons.
hatchet is offline   Reply With Quote
furnace problem captjack HVAC 8 11-23-2007 11:15 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 08:08 PM
