Square D Service Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 11:11 AM   #1
square d service panel question
my service panel has main and wh what is the wh slot used for?
kiwi7 is offline   Reply With Quote
Old 10-13-2011, 11:29 AM   #2
Code05's Avatar
Rewards Points: 1,104
You have an empty slot marked WH or a breaker marked WH?
WH will usually mean water heater in panel labeling.
Code05 is offline   Reply With Quote
Old 10-13-2011, 11:39 AM   #3
wh
it is two slots with knockouts on the same bus bars as the main breaker (top of panel)
Old 10-13-2011, 11:42 AM   #4
Licensed electrician
Rewards Points: 1,764
Water heater? Your question is a little vague.
gregzoll (10-13-2011)
Old 10-13-2011, 12:00 PM   #5
it is a square d qo 24 mwf series 2 the knockouts are still in place directly below main breaker and labeled wh
Old 10-13-2011, 12:19 PM   #6
it is on the same bus bars as the main breaker will only take a main style breaker knockouts intact labeled wh . it is a qo 24 mwf series 2. could this be used to supply workshop?
Old 10-13-2011, 12:24 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
How about posting a pic? That would make this MUCH easier.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (10-13-2011)
Old 10-13-2011, 01:31 PM   #8
square d pic?
hopefully here is a pic
Old 10-13-2011, 01:34 PM   #9
posted a pic on main pg
Old 10-13-2011, 01:40 PM   #10
DIY staff
Rewards Points: 7,174
Kiwi---please post all things right here---I hate merging and moving post around.
Moderator
Old 10-13-2011, 01:57 PM   #11
sorry
Moderator
not very computer savvy
Old 10-13-2011, 02:09 PM   #12
DIY staff
It took me a while to figure out the site,too---don't worry about it---You came for answers--not hassles--Have fun and carry on!
kiwi7 (10-13-2011)
Old 10-13-2011, 02:10 PM   #13
I=E/R
a7ecorsair's Avatar
Really? You did a nice job on posting a picture? Wait to see what the electricians on the forum say about your panel.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
kiwi7 (10-13-2011)
Old 10-13-2011, 04:16 PM   #14
That is a form of split buss panel. The top four spots (two breakers) are you mains.
Yours has a "lighting main" and an "A/C main".
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (10-13-2011), gregzoll (10-13-2011)
Old 10-13-2011, 05:44 PM   #15
Code05's Avatar
I thought the CEC required a shield for the service conductors.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Question on QO-20M Square D panel rovers1973 Electrical 6 02-06-2009 08:07 PM
Service Panel Basic Questions Monkey100 Electrical 14 11-13-2008 04:55 AM
New service panel + Generator transfer Nhrafan Electrical 1 04-21-2008 11:05 PM
