Square D QO Vs Seimens Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 12:06 PM   #1
Square D QO vs Seimens Panel
What is the better route to go for a sub panel, any advantage to either?
my new moneypit is offline   Reply With Quote
Old 01-10-2010, 12:11 PM   #2
I had a square D QOas my main panel
So for subs I also bought a Square D QO
Easier to swap breakers between panels if needed
Old 01-10-2010, 12:27 PM   #3
I look at the cost and availability of circuit breakers.
These days AFCI's, GFCI's, and a whole house surge protector which would take up a double breaker slot.
So your local stores may stock everything for one brand, and not much for the other.
Or they may fully stock everything for both brands, but one brand is less expensive.
It is nice to need a certain breaker and be able to go to the store and they have it in stock!
Billy_Bob is offline   Reply With Quote
Old 01-10-2010, 12:50 PM   #4
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Square D is chosen by more professionals than any other electrical panel. Both are of good quality.
However, one is a Cadillac and the other a Ford Focus.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 01-10-2010, 03:02 PM   #5
Idiot Emeritus
Rewards Points: 1,492
I think it depends on what type of Square D it is.
The QO is generally considered top of the line, while the Homeline is somewhere in the middle.
Square D QO are usually the most expensive panels and breakers, but in nearly 20 years of installing, repairing, and maintaining electrical equipment, (a lot of it in 'highly abusive' environments) I've found that you pretty much get what you pay for.
I don't have a lot of experience with Siemens resi panels and breakers, but the ones I've installed seem to be pretty well-built.
When I built my house 12 years ago, I chose Square D QO.
Rob
micromind is offline   Reply With Quote
Old 01-10-2010, 04:42 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
internally the SQ-D QO and Homeline are identical except for the orange visa-trip in the QO breakers so i was told by a square-d rep at supply house a few years back at open house.i always use Homeline for residential jobs
plummen is offline   Reply With Quote
Old 01-10-2010, 05:45 PM   #7
Inspector/Instructor
codeone's Avatar
The Square D QO has a lifetime warranty.
The Homeline Square D only has a 5 Yr. Warranty.
I have a Homeline in my house for the last 5-6 yrs works as designed no problems.
codeone is offline   Reply With Quote
Old 01-10-2010, 06:21 PM   #8
plummen's Avatar
whats the lifetime of a breaker? ive got homeline panels/breakers ive installed on jobs close to 20yrs ago without call backs
Old 01-10-2010, 08:24 PM   #9
Magnettica's Avatar
Rewards Points: 150
I use the Homeline for all my residential upgrades and never have any callbacks.
Old 01-11-2010, 01:53 AM   #10
" Euro " electrician
frenchelectrican's Avatar
I don't have any issue with SqD QO series and HOM series both been good to me so far asthe Seimens series they been good products as well.
As far for SqD products the QO is pretty much top of the line for both resdentail and commercal useage and HOM is pretty common used in remodel and new construction so both series are good useage.
And easy to find common breakers as need to.
Merci,Marc
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
