Square D QO Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 01:08 PM   #1
Saftety First!
Rewards Points: 77
Square D QO Panels
I was hoping to buy a 200A main panel set up for QO breakers (since I already have lots of QO breakers). But they seem to be difficult to find. Are these QO panels getting discontinued? Should I buy a different brand instead??
loyal is offline   Reply With Quote
Old 07-25-2011, 01:27 PM   #2
Sparky
Rewards Points: 510
Square D still makes QO panels, they're just pushing 'Homeline' for their residential panels now. You can find QO panels at some electrical supply houses
Techy is offline   Reply With Quote
Old 07-25-2011, 06:02 PM   #3
Electrical Contractor
kbsparky's Avatar
Try clicking here, for a main breaker QO panel.
I've dealt with these folks before, so they are legit.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
loyal (07-26-2011)
Old 07-25-2011, 06:43 PM   #4
Saftety First!
Rewards Points: 77
Looks great!!! I like the price too!
I have another question, if you have time.
Since my main disconnect is located outside my house,
do I still need a main breaker inside the house?
Old 07-25-2011, 07:24 PM   #5
Licensed electrician
Rewards Points: 1,028
You do not need a main inside if there is a means of disconnect outside. You may find a main breaker panel is cheaper than a main lug panel.
loyal (07-26-2011)
Old 07-25-2011, 09:39 PM   #6
kbsparky's Avatar
Originally Posted by loyal View Post
...Since my main disconnect is located outside my house, do I still need a main breaker inside the house?
Actually, no. And the main lug only panel is much cheaper.
-KB
loyal (07-26-2011)
Old 07-26-2011, 09:01 AM   #7
Saftety First!
Rewards Points: 77
Thanks KB!
I've followed the link you gave me.
Old 07-26-2011, 02:26 PM   #8
Rewards Points: 3,130
Home Depot sells both QO and Homeline panels. The Homelines are quite a bit cheaper and certainly good enough for residential use. That's what I used in my house.
The Following User Says Thank You to md2lgyk For This Useful Post:
loyal (07-26-2011)
Old 07-26-2011, 04:14 PM   #9
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I hate this. Do I get a Homeline unit for my home or do I get the QO??
My wife likes the fact that the QO will turn orange in the window when it pops. I could care less the cost is not overboard.
Big N8 is offline   Reply With Quote
Old 07-26-2011, 04:32 PM   #10
Rewards Points: 734
Go QO, not the Homeline. Yes, it's a few $ more.
It has a copper plated bus for lower resistance.
AandPDan is online now   Reply With Quote
Old 07-26-2011, 10:04 PM   #11
kbsparky's Avatar
Actually, it is a tin plated copper bus.
-KB
AandPDan (07-26-2011)
Old 07-27-2011, 12:15 AM   #12
Idiot Emeritus
Rewards Points: 1,492
There are exceptions of course, but I've found over the years that you get pretty much what you pay for with electrical equipment.
Generally speaking, the most expensive stuff will take the most abuse while the cheapest stuff is....well.....cheap.
This is certainly true with industrial stuff, but it also carries over to residential.
BTW, my favorite panel is Square D QO.
micromind is offline   Reply With Quote
Old 07-27-2011, 07:29 AM   #13
Sq D QO or Cutler Hammer CH panels...........copper buss. Homeline is aluminum buss.
Tags
no time like the present , type qo
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 10:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 10:29 PM
Square D Sub Panels Ranger Electrical 1 07-03-2007 01:49 PM
