Square D Panel Cover - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 10:13 AM   #1
square d panel cover
I am looking for a panel cover the part number is QOC20M F or S. It fits box number QOBW20M100-1. anyone have any idea where I can find one?
motofoko is offline   Reply With Quote
Old 02-13-2011, 04:12 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
I believe you're looking for a panel cover for a 20 space 100A QO panel. In which case you can special order one through Schneider Electric or a supply house, though buying it as a separate part is probably more expensive than just buying a new panel. If its the panel I'm thinking of, my local Home Depot and Lowes both sell it for $69.00. Its a pretty common panel that has been around for decades, just with different catalog numbers as the years have passed.
iminaquagmire is offline   Reply With Quote
Old 02-13-2011, 10:10 PM   #3
" Euro " electrician
frenchelectrican's Avatar
The electrical supply centre will or useally should have it in stock { if they stock SqD products } the cost that is the biggest question it will vaires a bit unless you check with some electricans some may have it on their shelf as well.
I used to keep couple before but allready sold them out.
Merci.
Marc
Square D Panel Cover chiro64 Electrical 11 11-14-2013 11:11 AM
Square D main panel TomA Electrical 2 10-16-2010 10:23 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Question on QO-20M Square D panel rovers1973 Electrical 6 02-06-2009 09:07 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
