Square D Interlock - Electrical - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 12:54 PM   #1
Square d interlock
If you were using a 60 amp breaker for your generator with the interlock kit to have your main off while gen is running is there enough room for the 60 amp to kick off if there is some kind of problem.
Kpack is offline   Reply With Quote
Old 12-26-2012, 01:02 PM   #2
TTW
TTW's Avatar
If you are using a listed interlock, should not be a problem.
The breaker on your gennie will probably kick first though...
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
The Following User Says Thank You to TTW For This Useful Post:
Kpack (12-26-2012)
Old 12-26-2012, 02:30 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I think you are asking if the handle has enough room to move to the off position if the breaker trips. The breaker has an internal trip mechanism and the handle does not have to move at all for it to trip internally.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Kpack (12-26-2012)
Old 12-26-2012, 03:47 PM   #4
Yes that's what I'm asking thanks
How to best tell what is square and what is not? miamicuse Building & Construction 12 07-14-2012 09:44 PM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 04:44 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 10:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 10:29 PM
