Square D Homeline Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 02:52 PM   #1
square d homeline breaker box
My main breaker only shuts down half of my box, and the neutral bar is hot. why?
leecorey is offline   Reply With Quote
Old 12-05-2010, 04:39 PM   #2
Licensed electrician
Rewards Points: 1,774
How did you determine that only half the panel gets shut off? Were you having power issues before the main was shut off?
Old 12-05-2010, 06:08 PM   #3
DIYer
A picture of your box would probably help as well.
Gigs is offline   Reply With Quote
Old 12-05-2010, 06:11 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I'm guessing the lugs are mixed up. One of the hots is probably going to the neutral bar and the neutral going to one of the bus bars. Just a guess though. Rather dangerous situation if that's really what it is.
Old 12-05-2010, 08:32 PM   #5
I=E/R
a7ecorsair's Avatar
Is the GEC missing or disconnected?
a7ecorsair is offline   Reply With Quote
Old 12-06-2010, 12:49 AM   #6
Rewards Points: 150
... and define "hot". Thermally, like burn hot, or electrically hot?
emolatur is offline   Reply With Quote
My 125A Square D HomeLine will not accept tandem breakers brons2 Electrical 3 11-01-2010 11:49 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 10:53 AM
Is the Square D Q0120GFI interchaneable with the HOM120GFI breaker? wideawake1 Electrical 8 07-11-2009 10:58 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
