Square D Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 10:02 PM   #1
Square d breaker
My electric panel was full so when I ran a new circuit I bought a mini breaker with two 15 amp circuit when I pushed the breaker in it sticks out, like it's not all the way down. I removed the breaker on the other side and could see that the breaker was all the way down do I have anything to worry about. It is a square d type tipo hom breaker.
Thanks,
Joe
heatycooly is offline   Reply With Quote
Old 03-28-2011, 10:48 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
Either your panel is not rated for those breakers or you are not installing it in the right breaker position. There should be a label on the panel that states which breakers are usable, ,if minis are acceptable and which positions you can use.
Coastal South Carolina
Old 03-28-2011, 10:52 PM   #3
Rewards Points: 256
Thanks,
Joe
Square D makes two styles the regular and the Hom:
I've grabbed the wrong one by mistake.
They cannot be interchanged.
michaelcherr is offline   Reply With Quote
Old 03-28-2011, 10:55 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Give us the model number of that load centre the number should be front of the load centre or the tub itself depending on which way the main breaker is located so it will be either side.
It should say HOM100M20F which that mean HOM- Homeline seriés , 100 - 100 amp , M - Main breaker 20 - 20 spaces ., F - flush
There are few others numbers as well but once you look up the load centre numbers then you should able tell if they can take twinner or not.
Merci.
Marc
Old 03-29-2011, 08:16 AM   #5
Ok I will get more info tomorrow did I mention that the breaker is working
Old 03-29-2011, 10:13 AM   #6
Scared Electrician
Saturday Cowboy's Avatar
I say he's got the right type of breakers but is trying to place it in a slot the will not accept the mini's. And yes it will "work" but Highly not recommended. Most panels only allow mini's in certain slots, say like the top 4 slots or something like that.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-31-2011, 05:59 PM   #7
Ok sorry took so long the panel is a cat no
Homc20u100c
Series s01
Type 1 enclosure
Square d
The breaker I put in is a
Old 03-31-2011, 06:00 PM   #8
Type homt
10 ka
Old 03-31-2011, 06:06 PM   #9
Licensed electrician
Rewards Points: 1,876
I think you have installed a tandem in a panel that does not accept tandems.
Old 03-31-2011, 06:09 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
What Jim said!
Old 03-31-2011, 06:12 PM   #11
So what do I do now
Old 03-31-2011, 06:15 PM   #12
I ran into this problem also. SqD changed its homeline panel acouple of years back. The new panels have alittle bit dif. Buss bar. On the breakers the plastic housing sticks down alttile farther now than the older breakers. I just used a file on mine to the housing of the breaker (right where the u clip is on the breaker) on the back side and took the extra off. It wasn't even a 1/16". It fit perfect after that. That was just my experiance and what I did to fix it. You could always add a sub panel though.
Jbyrd is offline   Reply With Quote
Old 03-31-2011, 06:30 PM   #13
Although you posted the part number for the cover I would guess that is a 20 circuit panel. You should not have more breakers than the panel is listed to accept. The rejection clip is designed so you cannot install more breakers than it was designed for.
You need to look at installing a subpanel for your additional circuits.
Old 03-31-2011, 06:32 PM   #14
Well what could be the harm in leaving this the way it is I do heating but do not feel comfortable installing a sub panel
Old 03-31-2011, 06:36 PM   #15
Technically it is a code violation. It may not fit on the buss correctly and could cause a burn spot on the buss which could cause the panel to need to be replaced. It could also start a fire.
Heat Pump trips breaker gt1935 HVAC 2 03-26-2011 10:06 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 10:53 AM
Is the Square D Q0120GFI interchaneable with the HOM120GFI breaker? wideawake1 Electrical 8 07-11-2009 10:58 PM
