Square D 150 Amp Homelite Panel Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 06:58 AM   #16
RustyRealtor's Avatar
Rewards Points: 283
Okay, I tried to attach a photo by hitting the attachment link on this reply page. Hope it works.
I concluded that I needed a 150 AMP breaker box because of the 150 AMP breaker which is located out next to the meter. I suppose it was an ASS-umption on my part. Hopefully a correct one.
Hope the photo shows up.
Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Old 04-15-2009, 07:07 AM   #17
Don't only know electric
Originally Posted by InPhase277 View Post
Asking if you did it right after the fact is kind of a bass-acwards way of doing things. Let me explain how these threads usually end. OP posts question about something they've done. They aren't really wanting to hear that they may have done something wrong. They are really just looking for reassurance they did it right, and thus really won't hear it any other way. Someone tells them that something is wrong, and explains why. OP says "But it works??". Someone else explains why it may work but is still wrong. OP has already done the job and doesn't want to hear any of that, so disappears and is never heard from again, most likely leaving his hack job just the way he finished it ignoring the good advice he recieved.
WOW! You said it all, I like your style.
SULTINI is offline   Reply With Quote
Old 04-15-2009, 08:47 AM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Thanks,
Russell
The breaker size is fine. If it had been smaller, say like a 100 amp, then that would actually control the protection of the feeder to the new panel and you would not have a 150 amp capability.
Two main breakers in your situation is redundant but poses no violation. Looks like you have neutrals and ground separated (I don't see the green main bonding jumper) which is good. It should not be installed. You may have an issue with too many cables through one clamp but I can't see that part very well.
All your bonding and grounding electrode system connections are out at the service disconnect at the meter I would think.
The SEU cable you ran should be capable of 150 amps minimum. It looks like it is ok but should verify it is 2/0 at least.
Wire management could be better but we have seen much worse here. If the cables run up that wall cavity they should be fastened 12" or so after they leave the enclosure.
Working space in front of the panel looks good.
Main thing is you do have 4 wires feeding the panel with neutral and ground separated and all bonding taking place out at the service disconnect by the meter.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 04-15-2009, 08:51 AM   #19
Rewards Points: 2,350
Thanks,
Russell
Looks pretty good. The only thing I would quibble about, as far as mechanical work, is that you brought a bundle of cables through one big knock out. It's not really serious enough to change at this point, but something that the inspector may not like. And for future jobs like this, don't do it.
You have 4 wires coming from the service disconnect, which is good.
EDIT: removed stupid comment made due to me not paying attention.
Old 04-15-2009, 08:53 AM   #20
Hey, I don't play... I broke my radio 'cause it played. I quit school 'cause of recess...
Old 04-15-2009, 08:56 AM   #21
UAW SKILLED TRADES
Stubbie's Avatar
You have 4 wires coming from the service disconnect, which is good. Now, locate the screw that bonds the left and right side neutral and ground bars together, and remove it.
Agreed. I don't think it is installed. I think on Homeline it goes in that hole above the right side neutral bar.
Stubbie
Old 04-15-2009, 09:46 PM   #22
Rewards Points: 283
Thank you all for your help. I have removed the green bonding screw.
Until Next Time,
Russell
Old 04-16-2009, 10:27 AM   #23
UAW SKILLED TRADES
Stubbie's Avatar
Complete junk for an electrician, nike is better served to trail huggers and pavement pounders.
Stubbie
Old 04-16-2009, 10:54 AM   #24
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Talking to yourself stubbie?
Old 04-16-2009, 11:01 AM   #25
UAW SKILLED TRADES
Stubbie's Avatar
Nope.. just responding to another spammer, looks like the administrator caught him right away....
I like tree huggers though....
I don't like bicyclers on two lane highways nikes or not.....
Stubbie
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Next Question, Sub panel in detached garage... OmegaBunny Electrical 5 09-15-2008 11:37 PM
Sub panel sizing and distance question fburke Electrical 13 06-11-2008 06:33 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
3 phase panel question curse21 Electrical 2 08-18-2004 10:17 PM
