Sqaure D Cover QOC40US Ser. S01 Sticker? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 10:47 PM   #1
Sqaure d cover QOC40US Ser. s01 sticker?
The sticker on both of my 200 amp qo load centers are messed up with pen, since circuits have changed, people used pen and re labeled. I would like to redo the wiring inside the panel a little to make it cleaner, and would like to mark some circuits (about half are not labeled on one panel). Are there any sticker replacements or cover replacements, I can't find any. Any alternatives to a whole cover, sounds expensive?
rgsgww is offline   Reply With Quote
Old 01-08-2009, 10:50 PM   #2
DIYer
You could use a little Dymo type label printer and print strips of paper to cover the old labels.
http://global.dymo.com/enUS/Categori...el_Makers.html
Gigs is offline   Reply With Quote
Old 01-08-2009, 10:50 PM   #3
Rewards Points: 2,350
Go Office Depot and pick up some sheets of printable label paper. Print up your own and stick them over the old stuff.
Old 01-09-2009, 05:10 PM   #4
Good Idea, going to get some at staples. Now to be safe, I should cover only the circuit labels, not the warnings, information, right? Or does it matter?
Old 01-09-2009, 05:15 PM   #5
I'd leave the panel information uncovered, if possible. Or maybe print up a sheet detailing that too.
Old 01-10-2009, 12:53 AM   #6
Its kind of alot of stuff to cover, Ill just measure up and try to print the circuits only.
The panel is a mess, they left out 4 screws, only two keeping the cover on because the spaghetti of wires pushes out the cover. I'm planning on labeling new circuits and cleaning it up. They then used romex connectors for bx without any bushings.
"They" are a bunch of licensed electricians. What crappy work they did...The worst so far was what I found (and fixed) in my crawlspace, I hate it in those! I might crawl up into my attic and take some pics of the "pro" work...
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 11:31 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Cover for Whole House Fan ntfspark General DIY Discussions 4 11-18-2007 01:57 AM
Patio cover Jackhammer Building & Construction 3 07-10-2007 04:49 PM
