Sq D Trillaint Breaker Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 08:08 AM   #1
Resident
Question
Sq D Trillaint Breaker problem
My house was built in 1993 and the electrician decided that using the new Sq D Trilliant Breaker box would be the way to go. I think he really did it because he was so darn cheap. My whole neighborhood has these boxes but I digress. Aside from the breakers being as scarce as hens teeth, they also seem to trip more often than any other breaker I have experienced and that brings me to my issue. About 3-4 months ago a breaker tripped and I tried to reset it but no matter what I did the breaker would not reset. There was no load on the circuit so I assumed that the breaker was bad. Fortunately I purchased an extra 15 amp breaker when I re-did the basement so I simply pulled the old breaker and put the new one in. Poof, everything worked fine. When I looked at the old breaker I flipped the tab and it reset but I did not re-install it thinking that there probably was still something wrong with it. Yesterday, my dryer 30 amp breaker tripped and now I can not reset it. I unplugged the dryer and shut down most of the breakers on the panel and it still won't reset. I am thinking that if I pull the breaker it will reset and will work when I put it back in. My question is: Has anyone had issues with these breakers ? I am thinking of having the whole box replaced.
Thanks in advance
JMR
jmreynol is offline   Reply With Quote
Old 04-28-2009, 09:21 AM   #2
Rewards Points: 3,130
I'd replace the panel. Yours hasn't been made since 1991 or so. I prefer the Squard D QO panel, but the Homeline is good too. And the breakers are readily available.
Old 04-28-2009, 05:54 PM   #3
" Euro " electrician
frenchelectrican's Avatar
It will be wise idea to just replace the whole panel due the breaker is pretty hard to find { I know they stop made them way back early 90's } so get a common SqD QO series or HOM series breakers with load centre they are far much more common with this set up.
Merci,Marc
Old 04-28-2009, 07:06 PM   #4
Resident
SQ D Trilliant Breaker Box - thanks
Just wanted to say thanks to those who responded. I changed the 30amp breaker and it is definitely broke. I am going to take everyone's advice and replace the whole setup. It will be cheaper in the long run.
JMR
Tags
trilliant
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 04:13 AM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Older breaker box problem (pics enclosed) bobz Electrical 11 12-21-2008 05:18 PM
Holy smoking commander breaker drogosandybanks Electrical 13 01-10-2007 02:34 PM
GFCI breaker problems bwoo Electrical 5 12-09-2006 02:53 PM
