#1 |
SPST Switch Strange Functions
I have a SPST (single pole, single throw) switch that controls two lights, but in a strange way. Light #1 is on and light #2 is off when switch is off. When you turn the switch on then light #1 turns off and light #2 turns on.
How is this possible with a SPST switch? My first thought it was switching the neutral, then I thought there must be a relay built into the system. This is an older house, no grounds involved. Any help to understand this would be appreciated. Dan |
#2 |
Licensed electrician
If you had a 3way switch and each light was wired off a different traveler terminal it would work as you describe.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 |
How many wires in the switch box?
#4 |
SPST Switch Strange Functions |
#5 |
Four wires in the switch box, all black (K&T wiring). Two wires connected, the other two wires terminate at the switch terminals.
#6 |
Resi EC
Are the light bulbs the same wattage?
#7 |
Resi EC
I'm thinking that some how the are run in series, but at the same time I can't see how with the SP switch interrupting power.
Just typing while thinking. |
#8 |
#9 |
There has to be a relay, thats the only way this is possible that I can see. The bigger question is why in the world anyone would ever wire something that way, where one light HAS to be on all the time?
#10 |
Light #1 is in a hallway and light #2 is in the closet. The switch is in the closet and when turned off the hallway light comes on and the closet light goes off. Yeah, it is strange!!
#11 |
Has this ever worked properly? Sounds like someone may have tapped a new light off a switch loop.
Do not PM with questions that can be asked in a forum. I will not respond. |
#12 | |
SPST Switch Strange FunctionsQuote:
Circuit has always been this way since the house was purchased several years ago. Could you diagram a "tapped ..new light off a switch loop" that would act like this? I don't see how that is possible, but a wire diagram would help. Thanks, Dan |
#13 |
Is there anything else controlled by this switch, for example a small heater?
Is the lamp (either lamp) that is off completely off versus glowing slightly? Try exchanging one lamp with a lamp of a different wattage. Does the switch behave differently?
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
#14 | |
Dan |
#15 |
When the switch is closed, is the "off" light really off ? If you put a meter on it, is it zero? Could the second light be connected from hot to a poor nuetral or ground, and when the switch is closed, current travels through the normal path?
| Display Modes | |
| Wiring in a 4-way Switch | RickSene | Electrical | 5 | 04-09-2013 08:25 PM |
| Rewire a switch that controls an outlet. | z00ropa | Electrical | 8 | 10-23-2012 07:00 PM |
| Generator Transfer Switch Trouble | wgramer | Electrical | 23 | 11-12-2011 08:23 PM |
| 3-way light with a twist | Jeepsail | Electrical | 14 | 05-18-2010 02:24 AM |
| 4 way switch confusion | Richo | Electrical | 10 | 04-09-2009 08:11 AM |
