Sprinkler System Causing Other GFCIs To Trip - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 04:42 PM   #1
Rewards Points: 77
Sprinkler System Causing Other GFCIs to trip
Ok, here is the situation.
I recently turned my sprinkler system back on for the summer. The sprinkler system (controller) is plugged into a Non-GFCI receptacle in the garage. The garage circuit is a 20A individual circuit.
When the sprinkler system is plugged in, a couple of the GFCI receptacles in my kitchen tripped. I know, with a certainty, that these kitchen circuits are not tied into the garage in any way, other than the breakers for these circuits are both in the same electrical panel in my basement.
So.... how is it possible that the sprinkler being plugged in could cause these other GFCIs to trip, when they are on their own separate circuits??? I am dumbfounded.
patented is offline   Reply With Quote
Old 05-28-2013, 10:19 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,750
Could the sprinkler system be spraying in the kitchen window.....
Sorry, given the facts as you stated with certainity, I am just as dumfounded.
Actually, do they do it repeadidly, or consistantly,,,, could it be be coincidental.
To the best of my knowledge, all your sprinkler system heads and manifolds are controlled only from the controller and its transformer on your one circut. Are there any different type sprinkler systems where its transformer could be on the kitchen circut.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-28-2013, 10:29 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,336
The sprinkler system could be acting as unwanted earth
this would trip the gfci.
Somewhere somehow your sprinkler system
is coming into contact with the earth line on the gfci
power circuit, if it provides an secondary path to earth
dmxtothemax is offline   Reply With Quote
Old 05-28-2013, 10:33 PM   #4
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Philly Master (05-29-2013)
Old 05-28-2013, 10:40 PM   #5
DMX... How can an additional ground to the GFI ground affect the GFI.
If that is what you mean, the op ought to be able to disconnect his GFI grounds, and they should work fine and not trip (as a test, because he would no longer have an EGC sytem at his GFIs.) Right?
Best...
Peter
Old 05-29-2013, 04:54 AM   #6
is coming into contact with the (earth line on the) gfci
Sorry I did a typo there !
I suspect there is a leakage path from these power circuits
And the sprinkler system is the cause,
and the sprinkler system could also be providing
an earth path for some of this current,
Old 05-29-2013, 08:22 AM   #7
joed's Avatar
Rewards Points: 12,850
I think the term earth in this case refers to the neutral not the ground. Difference in terms between US and Australia.
Old 05-29-2013, 10:42 AM   #8
Gotcha.... Thanks
Reviving an old sprinkler system winotron Landscaping & Lawn Care 7 03-14-2013 08:43 PM
Well water to sprinkler system questions C_J_GO Landscaping & Lawn Care 8 01-30-2013 09:34 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
How do I shut off the valve (sprinkler system) from the front yard to the backyard? chriskwash Landscaping & Lawn Care 2 08-31-2010 06:33 PM
Sprinkler System Nathan Landscaping & Lawn Care 1 02-09-2004 10:12 PM
