Sprinkler Head Looking Thing - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 04:18 PM   #1
sprinkler head looking thing
I have 2 sprinkler head looking things in the basement of our new house. It is a foil cone with a flat piece of foil that looks like a sprinkler (fire protection) head assembly. It obvioulsy isnt fire protection because there is no water supply. there are 2 small gauge wires coming out of the back of them. I have no idea what they are for. can anyone enlighten me....first post by the way
brianford is offline   Reply With Quote
Old 03-28-2011, 04:44 PM   #2
Master Electrician
Rewards Points: 3,750
Are the wires connected to anything such as an alarm panel. They could be rate of rise heat sensors or smoke detectors.
brric is offline   Reply With Quote
Old 03-28-2011, 05:58 PM   #3
it is not connected to any alarm panel. I just looked at the back of it and chased the wire. There were 4 wires black and white we on the same terminal and red and green were on another. the wires only connected to the other piece and there was no current in the wires. Is it safe to say that they have been abandoned or were used previously for somthing else. would a picture help?
Old 03-28-2011, 06:06 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
pics!!! we need pics!!!!
tcleve4911 is offline   Reply With Quote
Old 03-28-2011, 06:26 PM   #5
joed's Avatar
Rewards Points: 11,998
Pics needed and any info that is printed on them like maker or model numbers.
Old 03-28-2011, 06:34 PM   #6
Experienced
Jackofall1's Avatar
Hello and welcome Brianford, to the best DIY'r site on the web.
As the fine gentlemen before me has indicated, a picture is truly worth a thousand words, especially when you yourseld haven't any idea as to what you are trying to describe.
Mark
Old 03-28-2011, 07:01 PM   #7
i was having a touch time uploading them to the forum here is a link to the picasa album. Thanks for your help!
https://picasaweb.google.com/1033858...450/Mar282011#
Old 03-28-2011, 07:37 PM   #8
Rewards Points: 6,652
Only way to find out, is to trace the wires back under the insulation. I would not be surprised if they are not heat sensors for the Smoke/Fire detectors in the house. Also, how do you not know if there is not a panel? Do you own, or are you renting the property?
Old 03-28-2011, 07:42 PM   #9
I followed the wires. the two sensors are only connected to each other. they are not connected to the smoke detectors as the smoke & Co detectors are battery operated and not hard wired.
Old 03-28-2011, 07:43 PM   #10
own the house
Old 03-28-2011, 07:55 PM   #11
Rewards Points: 29
I believe those are old ionization-type fire detectors. I remember some of them had the capacity to connect together so that when one alarm goes off, so do all the others. Kinda like a stand-alone partial-house fire detection system, if that makes any sense...
OTOH, I could be as full of stuff as a Christmas turkey...
slickwilliam is offline   Reply With Quote
Old 03-28-2011, 08:13 PM   #12
Rewards Points: 81
Sounds like 2 old heat detectors.
Chevyman30571 is offline   Reply With Quote
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 08:33 PM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 02:37 PM
Adding a few sprinkler heads to existing argh Landscaping & Lawn Care 9 08-03-2010 01:07 AM
Pond aerator and Sprinkler system hd82 Landscaping & Lawn Care 0 07-31-2010 08:46 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 09:13 AM
