Sprinkler Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 03:33 PM   #1
Sprinkler box
I recently insatlled a new sprinkler box for a freind, the old box was hard wired directly into the box, but the new box had a regular plug like you would see on a regular indoor applance. I should have installed a electrical box outside but she did not want to pay for the materials, So i cut the wire and hard wired it like the old box, but now I do not have power?? I tested the line with a multimeter and have 120 volts on them. So i am thinking the wires might be backwards, is this possible with AC??? the sprinkler box had three wires black, white and green, (I assumed green was ground) and the wires coming from the circuit breaker panel are white, white and black. I tested a black and white wire and have 120 Volts, but does it matter how these wires are donnected to the box??? Right now I am using 1 white wire and 1 black wired from the breaker box and connecting them to the white and black wired from the sprinkler box. (the wires are coming directly from the circuit breaker panel box which is located right adove the sprinkler box)
dansan1975 is offline   Reply With Quote
Old 03-29-2012, 03:38 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You are a "handyman"/something else doing electrical work without a license?
Old 03-29-2012, 04:23 PM   #3
I do not understand the question are you a handyman?
what are you trying to say???
Old 03-29-2012, 05:01 PM   #4
seansy59's Avatar
Rewards Points: 258
All or most sprinkler timers are low voltage (usually 120v AC from the outlet converted 24v DC). They are the "blocks" or transformers you see that are also called "wall warts". If you bypassed this, then you just blew out the whole system possibly. If the wire is 18ga. or smaller going to the timer (kinda like a cell phone charger), then that would usually be low voltage.
Some are regular plug in or hardwired, with the transformer built into the timer, but this is not too common.
Thats all I have to say.........
seansy59 is offline   Reply With Quote
Old 03-29-2012, 05:02 PM   #5
Licensed electrician
Rewards Points: 1,502
Many areas have laws requiring a license to perform electrical work, especially when you are not working on your own house.
Old 03-29-2012, 05:13 PM   #6
DIY staff
Rewards Points: 7,174
Is there a wiring diagram on your 'sprinkler box' ?
If not did you go on line to get one?
What brand and model?
Old 03-29-2012, 06:28 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Links to what you bought and/or Pictures help a great deal when you are trying to explain what you did. Did you test the transformer before you cut the cord off. Once you cut a cold off you have void the listing and the warranty. Also this should be on GFCI if it's outside.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-29-2012, 06:53 PM   #8
transformer
I did hard wire before the transformer, so I do not think that is the issue, as far as diagram of it, there is three wires coming out of a conduit pipe coming from the circuit breaker panel, and then I hooked two of these wires in to the plug, imagina a regular cord you plug into the wall outlet.
Old 03-29-2012, 07:10 PM   #9
DIY staff
A wiring diagram from the product is needed--or a link so someone here can find it----
Next time don't let a cheap person dictate the proper way of doing things---Buying a GFCI breaker to protect that circuit is going to cost a lot more than the new GFCI outlet would have.
You realize that needs to be protected ,don't you?
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 07:33 PM
Assistance on Toro sprinkler system Dgreaney Landscaping & Lawn Care 5 06-12-2011 08:38 PM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 01:37 PM
Pond aerator and Sprinkler system hd82 Landscaping & Lawn Care 0 07-31-2010 07:46 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
