Spray Foam And Ground Wire. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 10:06 PM   #1
Spray foam and ground wire.
So i am going to have spray foam installed in my basement. One of the ground wires for my main service panel will end up partialy coverd by the spray foam. the grounding wire was previously inspected when the main service panel was updated. can the spray foam be installed over the ground wire?
bf514921 is offline   Reply With Quote
Old 07-12-2012, 10:09 PM   #2
Julius793's Avatar
Sure
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 07-12-2012, 10:28 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes, but the connection to the water pipe must be accessible.
Old 07-12-2012, 10:36 PM   #4
Master Electrician
Some spray foams I've seen can't be in contact with bare copper for some reason. Your hiring the job out to the professionals so they will likely already know all that and plan accordingly. I highly doubt they use a product like that but just tossing it out there.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-13-2012, 05:35 AM   #5
Yeha, i was going to ask them when they stopped by,
K-Buz thanks for the heads up, luckily the connection will be in the unfinished part of basement so i should be good there.
Spray Foam between Siding and Foundation? Peter D. Insulation 10 02-28-2012 11:33 AM
closed cell spray foam and terminates. gkaro Building & Construction 9 12-21-2011 09:05 AM
Garage Door rot- Spray Foam? whoppr Building & Construction 9 07-16-2010 02:36 PM
Spray foam or rigid for basement walls? upinsmoke Building & Construction 6 05-02-2010 04:23 AM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
