Spot The Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 07:53 PM   #1
Rewards Points: 6,652
Spot the problem
Updated. Been noted on other forum, that this was a set up, not actually happened. Interesting though as to what could happen if a person did not know what they were doing in a real life situation. The appearance would be the same if a out of control electrical fire happened after Arcing or Direct Short with overheating.
Old 02-08-2011, 08:05 PM   #2
fabrk8r
fabrk8r's Avatar
wow! that's scary...is that the switch that controls the internet?!
That right there is a good reason that a quick sketch is a good idea for anyone who doesn't do that kind of work on a regular basis.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-08-2011, 08:08 PM   #3
fabrk8r
fabrk8r's Avatar
I was sitting here wondering what the switch was supposed to control...then it dawned on me...that must be the ignition switch for the wood burning heater!
Old 02-08-2011, 08:09 PM   #4
Do have to love direct shorts.
Old 02-08-2011, 08:10 PM   #5
Rewards Points: 79
So assuming he replaced an existing switch that was working properly at one point what did he do? It's hard to tell as it looks like a "normal" switch wiring job. The only thing I could think is he put the ground on the neutral post but I can't tell if the insulation was burnt off or not.
If it was new wiring, he shorted it out and had no business attempting the rewire job.
Edit: Found the original post and that's what happened - he wired the ground and hot together...
itguy08 is offline   Reply With Quote
Old 02-08-2011, 08:40 PM   #6
I=E/R
a7ecorsair's Avatar
When did switches start having a neutral post
a7ecorsair is offline   Reply With Quote
Old 02-08-2011, 10:11 PM   #7
joed's Avatar
Rewards Points: 11,614
Why didn't the breaker trip? Why didn't the rest of the cable melt? Exactly what was supposed to have happened?
Old 02-08-2011, 10:30 PM   #8
Someone that made a failed attempt to rouse some regulars over at another forum, by using a torch to make it appear that a fault happened.
Old 02-08-2011, 11:00 PM   #9
joed's Avatar
I was going to say it looked like a torch job. I have seen switches actually on fire and they didn't look like that when the power was cut and the fire went out.
Old 02-09-2011, 12:05 AM   #10
Electrical Supplier
Rewards Points: 150
Yeah, burn patterns arent consistent with a true electrical fire.
THIS would NEVER happen in real life....trust me.
If you had a direct short like that, it would instantly arc and probably not burn for more than 30 seconds.....That is if the breaker didnt trip, which it SHOULD and more than likely would.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-09-2011, 12:18 AM   #11
Rewards Points: 506
Its 2011 already. Where is the neutral? That's why it burned.
jlmran is offline   Reply With Quote
Old 02-09-2011, 10:07 AM   #12
Even if that switch exploded it wouldn't make that much of a mess.
Hourglass52 is offline   Reply With Quote
Old 02-09-2011, 10:22 AM   #13
Rewards Points: 506
Isn't it a bit embarrasing that so many people actually know what the result of improper wiring actually would look like?
I actually have no idea how it should look.
Old 02-09-2011, 11:33 AM   #14
It's not embarrasing... it's important to understand how to do things correctly, as well as what will happen if something is done wrong. An insurance adjuster or arson investigator would need to be able tell the difference between a true wiring fault leading to a fire and an scenario staged to appear that way.
clashley is offline   Reply With Quote
Old 02-09-2011, 12:21 PM   #15
Have you ever worked on a house hit by lightening.? All sorts of crazy stuff happens.
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
