Splitting Your Input Before Your House Panel? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 10:07 PM   #16
Originally Posted by Jim Johnstone View Post
It's copper, 3 wires, with a ground stake at the garage. Two huge wires which are at least #3, and a third wire which is very slightly smaller, I'm assuming that's the neutral. He has one 220 volt circuit in the garage currently.
Originally Posted by Missouri Bound View Post
And I didn't see any mention of a grounding rod...and that would be needed at the garage.
Well done.
I mentioned it there. I have an email into the city's electrical department requesting info on the service size from the street to the meter on the house. They should have an answer to me this week.
Jim Johnstone is offline   Reply With Quote
Old 04-08-2011, 10:08 PM   #17
I=E/R
a7ecorsair's Avatar
Nap...my hat's off to you. You have done nothing but pose a very factual accurate presentation. You have me agreeing with you, hands down. My only concern would be as mentioned earlier, that the entrance drop wires were adequate to handle the additional amperage...could be, but probably not. And I didn't see any mention of a grounding rod...and that would be needed at the garage.
Well done.
MB, be sure to read the OP's original question. It was about finding a way to get power to his garage using some existing wiring and without upgrading his service. It was not about how to wire the garage panel.
a7ecorsair is offline   Reply With Quote
Old 04-08-2011, 10:10 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Yes, I must apologize to Mr Johnstone, I kind of hijacked the thread.
Old 04-09-2011, 07:45 AM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
This information is actually irrelevant. It's the service entrance size that matters.
The drop from the street is owned by the POCO and it's their call whether to replace it or not.
Speedy Petey is online now   Reply With Quote
Old 04-09-2011, 09:09 AM   #20
Can you clarify, when you say the drop you mean from the poles to the meter? The service entrance, is that from the meter into the house?
If the drop is not sized for 200 amps, doesn't it still pose some restrictions on whether I could have 100 amps in the house, and 100 in the garage?
Thanks,
Jim
Old 04-09-2011, 09:18 AM   #21
Missouri Bound's Avatar
Speedy refers to the wires that come from your meter up the service drop and out the head. At this point there is a connection to the utility, usually with compression connectors about 1-2' from the head itself. Very often these wires are sized for the main breaker, in your case 100 amp. These would have to be increased in size for a 200 amp system.
Old 04-09-2011, 09:58 AM   #22
I=E/R
a7ecorsair's Avatar
Thanks,
Jim
Is the power to house provided by your city or by an independent power company?
Old 04-09-2011, 11:23 AM   #23
I'm pretty sure it's the city (Brantford Hydro, Brantford Ontario).
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
new service panel The Barber Electrical 1 05-16-2008 05:49 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 05:47 PM
