Splitting Phone Wire To 2 Jacks - Electrical - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 10:44 AM   #1
Splitting phone wire to 2 jacks
Hi all,
I need to install another phone jack in our bedroom. Currently, there is only one in the kitchen. There is a closet between the two rooms and I can clearly see the phone wire running into the kitchen wall. I know that I can cut that wire and run it through the wall to the bedroom, but then the kitchen jack will be dead. I'm not having much luck in finding a splitter or something that would allow me to preserve the kitchen jack, as well as having a line run to the bedroom. Running a new line from outside is not an option as I'm a renter.
Thanks for any advice.
Ryan
liquidskin is offline   Reply With Quote
Old 12-26-2010, 11:02 AM   #2
Master Electrician
Rewards Points: 3,680
If possible, rather than cutting the existing wire, run a new wire from the existing kitchen phone jack to the new one in the bedroom, connecting to the screws on the kitchen jack.
brric is offline   Reply With Quote
Old 12-26-2010, 11:09 AM   #3
Thanks for the suggestion. That's a possibility, but might be a bit tricky for me as I would need a staple gun, some new wire. I guess I was looking for the simplest approach. Do I have any options with cutting the wire?
Old 12-26-2010, 11:23 AM   #4
I have cut phone wire and spliced an additional cable. I soldered the splice joint, then used small wire nuts and tape to keep it all together. Keep like colors together, and I expect you would be fine.
oberkc is offline   Reply With Quote
Old 12-26-2010, 11:27 AM   #5
Master Electrician
3M manufactures phone wire spicing devices.
Available at Radio Shack.
http://www.radioshack.com/product/in...ductId=2062793
Old 12-26-2010, 11:38 AM   #6
Very cool. Please correct me if I'm wrong... I could cut the existing line, stick each wire in a connector with the new wire and the other end of the cut wire, seal it up and be done?
Old 12-26-2010, 12:27 PM   #7
Master Electrician
Yes. Insert the wires, unstripped, crimp the red button down with a set of pliers.
Old 12-26-2010, 12:31 PM   #8
Thanks for your help! Im going to give it a shot.
Old 12-26-2010, 08:57 PM   #9
RCDD
Or you could buy a cordless phone with the seperate base station that does not need to have a phone jack.
dannykapp is offline   Reply With Quote
Old 12-26-2010, 10:28 PM   #10
Rewards Points: 518
The traditional method is to use B-Wire crimps. You simply placed the unspliced wires inside the connector and crimp down(preferably with a "B" crimp tool, but pliers work). Electrical wirenuts were not designed to be used on such thin easily breakable wire. It is doable but you'll never catch a telco installer using them.
n0c7 is offline   Reply With Quote
Old 12-26-2010, 11:40 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the connectors brric showed are made specifically for this type of application.
Old 12-26-2010, 11:56 PM   #12
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by liquidskin View Post
Hi all,
Ryan
I make that part bold due you are renter and did you talk to your landlord about this situation first ??
As far for the connectors I use the same as Brric show on the list here I have used both in USA and France so I go thru a bit of them.
However please pay attetion to the conductor colours espcally if you have diffrent colours show up. { it will happend one way or other so be prepared for that }
Red and Green is most common one but bleu and bleu with white stripe is common as well that for single line set up for other let us know we will list other colours.
Merci.
Marc
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
UVerse - Wire New Phone Line jhewitt Electrical 1 05-13-2010 05:29 PM
installing more phone jacks JAVAMAN General DIY Discussions 6 11-27-2007 09:37 AM
couple questions about installing phone jacks joeyboy Electrical 31 10-09-2007 03:26 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-18-2007 12:46 AM
