Splitting The Neutral On A Generator Transfer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 10:50 AM   #1
Splitting the neutral on a generator transfer switch
Can a transfer switch neutral be split between two seperate electrical panels.ie a six circuit transfer panel ,taking three circuits from each panel,only problem is there is only one neutral cable coming from the transfer switch harness.
Bdkhs is offline   Reply With Quote
Old 11-04-2012, 11:06 AM   #2
Rewards Points: 1,534
deleted
Old 11-04-2012, 11:13 AM   #3
Search google.com for the words...
neutral switching transfer switch
and...
separately derived system generator
and...
non-separately derived system generator
Billy_Bob is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Switch neutral wiring Terabitdan Electrical 4 12-29-2011 06:03 PM
Splitting two 3 way switch to two 2 ways BigDuke6 Electrical 2 11-14-2011 04:01 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
