Splitting Cat5 Into Two Jacketed Halves - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2016, 02:33 PM   #1
Rewards Points: 51
Splitting cat5 into two jacketed halves
I am hacking away at a project where I need to carry two signals on a cat5. Is there a product I can use to split a cat5 in half, and have the two halves still have a jacket? This helps me crimp the connectors to the two halves.
I hope this makes sense. I can do it now, but the connectors hang precariously from the two thin wires I scooped up for each half.
I cannot use something like a balun, since I want to pick which wires pair with which. My cat5s do not currently have connectors, but I could add them if needed.
injvstice is offline   Reply With Quote
Old 01-05-2016, 02:40 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 3,490
Use heat shrink tubing.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
injvstice (01-05-2016)
Old 01-05-2016, 03:11 PM   #3
Rewards Points: 51
Thanks, that would work in a pinch. It still looks a little ugly (especially near the Y joint), but if it's the best I can do, I will do it. I was hoping for a passive Y splitter for a CAT5. I'm not running ethernet over it, so it would work for me.
Thanks for the suggestion!
Old 01-05-2016, 03:37 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 6,152
Google is your friend....type in Cat5 Splitter
Here is just one example
http://www.officedepot.com/a/product...r9YBoCutfw_wcB
Old 01-05-2016, 05:11 PM   #5
Rewards Points: 51
Thanks. That won't work for me, since the box is too bulky (I need possibly 10 of them in one location). I was hoping I can find something that splits a CAT5 into two bare cables. Or something like a generic Y connector with at least 4 wires and no specific connectors at either end.
That box would've worked better if it split to two male cables, bulk aside, then I can chop off the connectors. Yes, I could plug in a cable into both outputs, but the unnecessary female connectors add bulk.
I will go with the shrinkwrap approach, thank you.
Old 01-05-2016, 05:22 PM   #6
A "Handy Husband"
rjniles's Avatar
If you use the shrink tubing: Remove the CAT5 sheath, split into the 2 pair groupings. Use 2 pieces of shrink, 1 on each group. Slip another piece of shrink to cover both and the wye joint.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Jim Port (01-05-2016), Msradell (01-05-2016)
Old 01-05-2016, 10:36 PM   #7
Msradell's Avatar
Rewards Points: 1,704
You can also get heat shrink tubing in many colors so you could match or contrast the outer sheath cover of your cat5 cable. You can also easily identify the difference between the 2 pairs you pull off the end.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
New Cat5 line install questions diynewbie11 Electrical 31 08-18-2013 04:44 PM
Running data cat5 cable in walls fdmillion Electrical 2 01-17-2013 08:15 PM
Is it okay to splice "live" cat5? Tryvidy Electrical 8 02-13-2012 02:54 AM
Hardwood floor splitting cillejo Flooring 3 03-08-2011 03:33 PM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 01:45 PM
