Splitting 240 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 06:37 AM   #1
Splitting 240
Outside next to my electric meter I have a panel with incoming 240 service. I want to split this to two 120 to so I can run 2-3 20a breakers to my shed/workspace and a couple 20a circuits to my deck/enclosed patio which has refrigerator tv and a few other electrical devices. Can someone please tell me how I would do this split at the panel
dmoore58 is offline   Reply With Quote
Old 06-28-2009, 06:52 AM   #2
Is this your main service panel?
jerryh3 is offline   Reply With Quote
Old 06-28-2009, 07:57 AM   #3
Rewards Points: 1,548
You must have a neutral in order to make a pair of 120 volt circuits out of a 240 volt line.
If your main disconnect switch is at that location then a neutral will run from there down to your house panel which is now technically a subpanel. Just downstream of your main disconnect there you can wire in additional 120 and/or 240 volt lines and run them to subpanels in your various detached buildings, one feed -- 4 wire for 120/240 (hot, hot, neutral, ground) or 3 wire for 120 volt only (hot, neutral, ground) -- per building.
You may not run a feed from there to a patio or other location attached to your house given the one feed per building rule. Instead you must run the lines from the panel in your house.
Your city may require a special permit or a separate permit to do work upstream of your main disconnect switch. In addition you may need to have your power company (sometimes abbreviated POCO) disconnect your service during that part of your project.
Splitting 1 register to 2? bigburb HVAC 1 05-15-2009 04:03 PM
hardwood tongue is splitting with nailer atomilano Carpentry 10 05-04-2009 08:05 AM
help - pressure treated 4x4 deck posts splitting frank090870 Carpentry 17 05-03-2009 06:19 PM
Cracked splitting cedar siding Wisco Painting 4 07-15-2008 12:10 PM
Teak Dining table is splitting mgraham803 Carpentry 2 03-13-2008 05:51 AM
