Splitting 200 Amps, Help With Parts Please - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2007, 12:13 PM   #1
splitting 200 amps, help with parts please
I will be building a small barn first, then the house. The meter socket will be installed on the barn (from underground) when it is ready, and stay there permanently. Ultimately, I want to get all 200 amps to the basement main panel. The future needs of the barn would be well supplied with a 50 amp panel. What is the best way to accomplish this? Is there a product available that could install after the meter socket (inside the barn) and take 50 amps to a barn breaker panel and 200 amps to the house?
tuolumne is offline   Reply With Quote
Old 03-30-2007, 01:01 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I use a 200 amp, feed-through, meter/main panel.
This is an enclosure that has the meter, a main breaker, about 6-8 spaces for regular breakers, and feed-through lugs that feed out the full 200 amps that can go on to the house.
You would use the breaker spaces to give you temp power and to feed your 50 amp barn panel from.
Every major manufacturer makes them.
Old 03-30-2007, 01:09 PM   #3
Thanks, this is exactly what I'm looking for. Does this... http://www.geindustrial.com/publibra...ct%20Sheet.pdf ...fit your description? Would I pop up into this, then take 200 back underground to the house and 50 through the wall into the barn?
480 voltage to 200 amps girl who needs info Electrical 1 08-01-2007 05:48 AM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 09:14 PM
can't find old replacement parts, need Air Handler coils, junkyard? sammibah HVAC 2 07-02-2006 08:43 AM
Amps to Watts Darylh Electrical 14 06-26-2006 12:57 PM
