Splitting A 14-3 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 03:55 PM   #1
Splitting a 14-3 wire
I have a 14-3 wire and I tied 2 14-2 wires into it by spicing one of the 14-2s black to the 14-3s black and the other 14-2s black to the 14-3s red then spliced all the whites together, as well as all the grounds together. The 2 14-2's run to outlets. Everything worked fine. I then tried to run another 14-2 off one of the outlets to add a 3rd outlet. I now have the power back on and the Red wire coming off the 14-3 is no longer hot, any idea why this happen??
jsweeney is offline   Reply With Quote
Old 01-04-2011, 03:58 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
Did you use a 2 pole breaker, or 2 sigle pole breakers with a handle tie.
Sounds like maybe the breaker for the red wire is off and did not reset.
That happens a lot with handle ties.
Old 01-04-2011, 04:00 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
How did you connect the 14-3 in the breaker panel?
Coastal South Carolina
Old 01-04-2011, 04:01 PM   #4
I believe it is a 2 pole breaker. None of the breakers are off or tripped.
Old 01-04-2011, 04:04 PM   #5
I do not know exactly how it is connected, it is original wiring from the house. (A quick background, a while ago we removed a wall between 2 rooms were the 14-3 was coming down it has been sitting in the attic since, I am now replacing the wall and using the original 14-3, it is on a single breaker)
Old 01-04-2011, 04:08 PM   #6
A "Handy Husband"
rjniles's Avatar
First you said a 2 pole breaker, then you say a single breaker. Need more detail, how is the 14-3 connected in the panel?
Old 01-04-2011, 04:15 PM   #7
Master Electrician
Rewards Points: 3,808
How do you even know the 14-3 is part of a MWBC ?
brric is online now   Reply With Quote
Old 01-04-2011, 04:23 PM   #8
Rewards Points: 1,492
Did one of the connections fall apart?
Maybe a wire broke inside the insulation and therefore you could not see the broken connection.
Old 01-04-2011, 04:33 PM   #9
Hey guys, my apologies, im a little new to the electrical world, i read books and google things to find my answers, but this one i can not figure out. A single breaker turned off power to both the red and black hot wires. When I ran 2 14-2 off the 14-3 and the 2 outlets connected to the 14-2 wires worked fine. The problem rose when I ran a 3 outlet of one of the other outlets, now my red wire is no longer hot. I checked all the GFI's throughout the house and none are tripped, I have also made sure that all the breakers are on, visually and by turing them all off and back on.
Old 01-04-2011, 04:40 PM   #10
A "Handy Husband"
rjniles's Avatar
I think you are over your head. If a single breaker turned off power on both the black and red conductors, then that circuit is wired wrong. Unless you mean a 2 pole breaker, then you are dealing with a MWBC (multi wire branch circuit). If you are not familiar with a MWBC you should get an electrician involved.
Old 01-04-2011, 04:47 PM   #11
The wiring hasn't been touch since the original builder, and it passed inspection so I am doubting it is wired wrong, meaning it must be a 2 pole breaker. A MWBC simply put is hot wires sharing a neutral right? How could 1 hot wire not be getting power and the other be getting power on a 2 pole breaker? Any ideas?
Old 01-04-2011, 04:47 PM   #12
WaldenL's Avatar
Rewards Points: 268
What you described _should_ have worked, so there's a problem somewhere. I don't see why GFCI's elsewhere in the house would have any effect, but hey, if you just tested them that's a good thing. :-)
On the breaker front, can you clarify the connection of the 3 wire? Presumably the Red wire is under one screw and the Black under another screw, and the two screws are right next to each other, yes? And the two screws are attached to breakers that have their handles tied together? That is, it's not possible to turn one off w/out turning the other off, right?
If the change you made was downstream of the 3-wire than the only thing that makes sense is a breaker issue. Sure, something could have come loose under a nut for the red wire, but you weren't messing with that wire at all, right? Your changes were on the other side of the 14-2?
You had:
Code:
Breaker ------3 wire ---- Junction ---- 2 wire ---- Plug
                              +---------2 wire ---- Different Plug
You changed it to:
Breaker ------3 wire ---- Junction ---- 2 wire ---- Plug ---- New Plug
Yes?
WaldenL is offline   Reply With Quote
The Following User Says Thank You to WaldenL For This Useful Post:
jsweeney (01-04-2011)
Old 01-04-2011, 04:57 PM   #13
A "Handy Husband"
rjniles's Avatar
Why don't you just identify the breaker controlling the circuit and stop all of us from guessing. Either it is a 2 pole or it isn't. And just because it passed inspection does not mean it was ever wire correctly. Stranger things have happened.
Old 01-04-2011, 05:20 PM   #14
Thanks walden, yes your code is exactly what is was doing
But sorry i made a mistake it is 2 single pole not a 2 pole circuit
Old 01-04-2011, 05:23 PM   #15
WaldenL's Avatar
Rewards Points: 268
OK, then I really think something is wonky on the breaker front. Photos help a lot. Can you snap a few w/the cover off?
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
