Splitting 12-3 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 06:50 AM   #1
splitting 12-3 wire
I want to feed two circuits with a single home run using 12-3 wire to two circuits in a kitchen, one is for a ac (window unit) the other circuit is for the fridge, both will be single outlets, nothing else run or any other outlets, question is can I place a 4" box in the wall without future access to split the circuits?
boyddw2 is offline   Reply With Quote
Old 04-19-2010, 07:17 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Absolutely not. A junction box MUST be accessible.
Why not just go to the first one, and then on to the next? Why bother with another box at all?
Old 04-19-2010, 07:18 AM   #3
No.
-As a rule, electrical connections can fail and might need maintenance. Needs to be accessible in the future.
-When there are problems with an electric circuit, sometimes you need to disconnect wires for troubleshooting. And you need access to the wiring connections to do this.
-Electrical circuits often need to be changed or added onto. You would need access to the junction boxes to do this.
-Murphy was right!
Also what you are talking about is called a MultiWire Branch Circuit or MWBC. Might want to read about that as there are *important* safety considerations...
http://www.google.com/#hl=en&source=...6b5a4f84435186
MWBC and new electrical code rules...
http://www.google.com/#hl=en&q=Multi...6b5a4f84435186
Billy_Bob is offline   Reply With Quote
Old 04-19-2010, 08:25 AM   #4
Just call me Andrew
Rewards Points: 1,020
Unless you have experience with electrical work, I'd advise against a MWBC (two circuits sharing a neutral). Like Billy_Bob said, there are very important safety considerations to take, including pigtailing outlets and using a double-pole breaker (or handle ties).
Andrew
secutanudu is offline   Reply With Quote
Old 04-19-2010, 05:16 PM   #5
no it is not feasible to go from one circuit, then on to the next, I also thought that it had to be accessible, however I do not have any issues as to sharing the neutral, been there and done that, yes I do double pole the breaker, but if it were a normal circuit for multiple outlets then the home runs would be separate, this however is only one outlet per circuit. I was just trying to avoid multiple runs in a old wall, It looks like I will be doubling up the wall thickness anyhow.
Old 04-19-2010, 07:14 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
run to the first recep box and then backtrack to the point you were considering putting a junction box and then going to the second recep location. It takes more wire, of course, but it prevents a buried junction box and still allows the use of the MWBC.
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 01:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
