Split Outlet And Two Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 03:32 PM   #1
Split Outlet and Two Switches
I'm trying to figure out how to wire this.
I have power running to a 15 amp outlet with just 14/2 cable. I want to install two switches above this outlet.
I want switch #1 to control the top of the outlet and keep the bottom always hot. I want to switch #2 to control another light receptacle I haven't yet installed.
I know how to wire a split outlet on one switch, but how do I also carry the current to the second switch so that I can independently control a different light fixture?
Thanks for reading
dvation191 is offline   Reply With Quote
Old 01-03-2010, 03:59 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Thanks for reading
Run 14-3 to the new double switch box from the existing receptacle. Use to run hot, neutral and a switched hot back down to the split receptacle. Loop the hot to both of the new switches. Continue the second switched hot and the neutral to the new light.
Take this in the best way, but if this doesn't get you there you need an electrician.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-03-2010, 04:01 PM   #3
To power a switch for the light, what would be the problem of adding a 14-2 wire between the plug and switch box? From there you would add a 14-2 wire between the switch box and light fixture box. The switch would interrupt the line (black) as it feeds the light.
I cannot speak to whether this is code compliant (lights on the same circuit as outlets). Also, you are starting to get a lot of wires in the outlet box, which may also have code issues and be otherwise difficult to stuff in the box.
oberkc is offline   Reply With Quote
Old 01-03-2010, 05:35 PM   #4
joed's Avatar
Rewards Points: 12,918
Remove the tab one the hot(gold) side of the first receptacle. The second one is not shown as split.
Old 01-03-2010, 06:28 PM   #5
Awesome! Doesn't get much clearer than that. You guys rock - thanks!
