Split Circuit Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 04:16 PM   #1
Split circuit wiring
Can you confirm that split circuits in a kitchen have a single circuit dedicated solely to each individual outlet, and t shared with any other outlet in the kitchen?
Thank you.
Ian Cross
Ottawa
Ian Cross is offline   Reply With Quote
Old 11-07-2010, 04:22 PM   #2
Rewards Points: 1,192
No. I'm not insured outside the U.S.A.
bobelectric is offline   Reply With Quote
Old 11-07-2010, 06:43 PM   #3
joed's Avatar
Rewards Points: 11,566
Split wired 15 amp circuits in a Canadian kitchen have two circuits connected to one receptacle. The tab is cut off on the hot(gold) side of the receptacle.
If a multi wire branch circuit (split circuit) is wired with 20 amp then you can use one circuit for each T slot duplex receptacle.
The Following User Says Thank You to joed For This Useful Post:
Ian Cross (11-09-2010)
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Rewiring older house WillK Electrical 12 10-13-2010 02:49 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
