Split Circuit Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 01:06 PM   #1
I need to "tap" into an existing split circuit recaptacle so I can run a power line to my dishwasher. Can somebody please advise the correct way to do this.
Buster
buster666 is offline   Reply With Quote
Old 02-25-2009, 01:09 PM   #2
How much power does the DW require?
What outlet are you tapping off of?
You aren't allowed to tap off of the 2 kitchen small appliance circuits
Where are you located?
Old 02-25-2009, 01:23 PM   #3
Remodeling Contractor
Run a new line to the DW.. Check local codes, you also need a switch for a fixed appliance disconnecting means.
Old 02-25-2009, 02:08 PM   #4
joed's Avatar
Rewards Points: 12,892
Split circuit sounds like a kitchen counter receptacle. You can't tap it for a dish washer. It must remain for kitchen counter only.
If it is not a counter receptacle then simply use one of the hot wires and the white wire + ground.
Old 02-25-2009, 07:16 PM   #5
Split circuit receptacle
I live in Ottawa, Ontario.
Yes, I was hoping to use one of the counter receptacles but that seems to be out. The panel identifies several "kitchen split" breakers.
I don't know how much the DW draws I do not have the owner's manual handy.
Old 02-25-2009, 07:28 PM   #6
Originally Posted by buster666 View Post
i live in ottawa, ontario.
Yes, i was hoping to use one of the counter receptacles but that seems to be out. The panel identifies several "kitchen split" breakers.
I don't know how much the dw draws i do not have the owner's manual handy.
1.2 kw
splitting circuit at receptacle box joey b Electrical 12 01-01-2009 08:39 PM
Adding a receptacle to existing circuit dekohl Electrical 3 09-10-2007 01:46 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
