Old 01-05-2012, 01:38 PM   #1
Split Buss? how to disconnect power?
I have a split buss panel. I'd like to change the wiring to the double pole 20A breaker in the bottom right corner. It is currently wired for an electric stove. The stove doesn't exist. We have gas. I'd like to use the breaker to run 8 gauge wire into another room to make a sub panel.
How do I shut off the power to the breaker so I don't get zapped?
Split Buss?  how to disconnect power?-panel-1.jpg   Split Buss?  how to disconnect power?-panel-2.jpg   Split Buss?  how to disconnect power?-panel-3.jpg   Split Buss?  how to disconnect power?-panel-4.jpg
tom1973 is offline   Reply With Quote
Old 01-05-2012, 01:44 PM   #2
Julius793's Avatar
First it not called a split bus anyways there has to be a main some where, look for one by the meter. Even after you shut it make sure to TEST!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-05-2012, 01:55 PM   #3
Clean up this panel first. You've got several violations on it.
For a start - Open knockouts need to be closed and cables need to be secured where they come into the panel.
AandPDan is offline   Reply With Quote
Old 01-05-2012, 01:59 PM   #4
MarginallyQualified
And while you have the power off... clean that mess up!
Better yet just change it out.
Old 01-05-2012, 02:01 PM   #5
Licensed Pro
That's not a split bus panel. It is a mail lug panel. Only way to disconnect power to it is at the source of the wires feeding it. This may be a breaker or it may be from a meter.
HouseHelper is online now   Reply With Quote
Lost power to two Rooms and Cannot Get it Back Zinge Electrical 9 08-08-2011 10:13 PM
Intermittent Brief Power Outages in Half the House mac70pete Electrical 11 06-02-2011 10:35 PM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 06:39 AM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 03:38 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 08:12 PM
